69 Charger A/C heater box vacuum hose diagram??? #178874
12/30/08 03:08 PM
12/30/08 03:08 PM
Anonymous OP
Anonymous OP
Anyone got a diagram of where the hoses run? I've got a customer's car here and rats have eaten most of the lines in two........
Thanks, in advance........
Re: 69 Charger A/C heater box vacuum hose diagram??? #178875
12/30/08 07:38 PM
12/30/08 07:38 PM
Anonymous OP
Anonymous OP
Bump.....................
Re: 69 Charger A/C heater box vacuum hose diagram??? #178876
12/30/08 11:15 PM
12/30/08 11:15 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Big Squeeze - there are probably pics & diagrams in a '69 Dodge service manual so shouldn't be too long before someone can post some or maybe you have access to one. I can send you pics from a '70 plymouth service manual for a satellite a/c box tomorrow night if you think they might help.
Re: 69 Charger A/C heater box vacuum hose diagram??? #178877
12/30/08 11:49 PM
12/30/08 11:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I have a 69 fsm and can scan them for you. Let me know if you still need them.
Re: 69 Charger A/C heater box vacuum hose diagram??? [Re: NITROUSN] #178878
12/31/08 10:00 AM
12/31/08 10:00 AM
Anonymous OP
Anonymous OP
Yes, I still need a diagram......... email is afxplymouth@sbcglobal.net
Re: 69 Charger A/C heater box vacuum hose diagram??? #178879
12/31/08 04:12 PM
12/31/08 04:12 PM
Anonymous OP
Anonymous OP
bump.......................
Re: 69 Charger A/C heater box vacuum hose diagram??? #178880
12/31/08 05:41 PM
12/31/08 05:41 PM
N
NITROUSN Offline
NITROUSN  Offline
N
This tells you what vacuum servo motor each port goes to.
Re: 69 Charger A/C heater box vacuum hose diagram??? [Re: NITROUSN] #178881
12/31/08 07:54 PM
12/31/08 07:54 PM
Anonymous OP
Anonymous OP
That's perfect.......THANK YOU........
Re: 69 Charger A/C heater box vacuum hose diagram??? #178882
12/31/08 10:03 PM
12/31/08 10:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No Problem. The fsm is so-so on the rest. If you need more pics or info I can copy the area that you want. The fsm does not have a laid out schematic drawing like wiring does.
