SSBC special from Yearone? #178808
12/30/08 12:02 PM
12/30/08 12:02 PM
Great Lakes State
O
ONEBADBIRD Offline OP
O
Great Lakes State
Anybody order or use this kit? I've heard good things about SSBC. How easy is this so called bolt on kit? What would I need that this package does not include? Thanks for answering all my questions. Jay
Re: SSBC special from Yearone? [Re: ONEBADBIRD] #178809
12/30/08 12:55 PM
12/30/08 12:55 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
I used their kit on my 70 Road Runner. Overall I liked the kit and it installed very easy. It came with everything that I needed.
I have used the kit as both manual brakes and power brakes. The manual brakes worked perfectly with the supplied master cylinder and gave me no problems.
The power brakes I had some trouble with. The booster (single diaphram) and master cylinder that it came with; I could not get them to work well at all. Panic stopping was out of the question. So I took an original dual diaphram disc brake booster for a 70 road runner and a 15/16" disc brake master cylinder and then everything worked great!
The booster and master cylinder that comes from SSBC is from a late 70's corvette and for whatever reason I could not get them to work well at all. Hope this helps! - Brian
Re: SSBC special from Yearone? [Re: ONEBADBIRD] #178810
12/30/08 12:59 PM
12/30/08 12:59 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
Jay,
I purchased the SSBC front disc brake kit for my '71 Dart GT ($830 to my door from Mancini). It is a complete bolt on ordeal. Everything fit as described. I would/will buy from SSBC again if/when needed.
Good Luck!!
Re: SSBC special from Yearone? [Re: DartGTDan] #178811
12/30/08 07:14 PM
12/30/08 07:14 PM
Great Lakes State
O
O
Great Lakes State
Thanks for the info,Jay
