Trailer tires...again #1787731
03/25/15 12:56 AM
03/25/15 12:56 AM
Anoka County, MN
Leigh Online content OP
Leigh  Online Content OP
Anoka County, MN
I got a tip to look for LT23585R16 tires, that declare the entire UTQG code, not just load range. When you look, you will find VERY FEW that do. A friend told me that he has had excellent luck with Hankook DynaPro HT. Guess what, they show temp of A. I'm going with those, or Mastercraft Courser R/D, also temp A. The replacement interval on trailer tires has been well documented, but knowing the temp rating can't hurt.
Re: Trailer tires...again [Re: Leigh] #1787732
03/26/15 01:30 PM
03/26/15 01:30 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I live in the desert... I just bought six new tires back in October. In 1.75 years I'll have to buy four more new ones.... the other two are spares that I carry. I hate tires.... I hate trailer tires.... but it is what it is.
we got four years out of our OE china made 16" tires. I'm betting I'll only get two now that the trailer is in AZ.
Re: Trailer tires...again [Re: J_BODY] #1787733
03/26/15 10:02 PM
03/26/15 10:02 PM
Can't buy good ones for any price--if you are lucky and have 16's the truck tires work--
I have tossed more full tread trailer tires than race slicks it sucks that even in the USA you can't buy a decent trailer tire at any price--
I am reminded of the fact that the year I was born 1957 there were over 100 factory making Levis--last one in USA closed years ago--now I have to buy Deluth trading or Carhart jeans at stupid $$ to have any worth a damn--
Just bought 4 china specials yesterday and hope not to get killed by the highway changing tires this season--
Re: Trailer tires...again [Re: ] #1787734
03/26/15 11:05 PM
03/26/15 11:05 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Onlt Tires I use on my 53' LQ race hauler....not cheap when buying 6...but they LAST !!!!..pulled through Vegas at 115 degrees...a few times...no issues..
http://www.trailertiresandwheels.com/235...al-trailer-tire
Re: Trailer tires...again [Re: Chassisman] #1787735
03/27/15 03:11 AM
03/27/15 03:11 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well you pulled through Vegas.... ain't that quaint. Try living out here and watch them turn to dust!
Re: Trailer tires...again [Re: J_BODY] #1787736
03/27/15 03:53 AM
03/27/15 03:53 AM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Cen Cal isnt much cooler..LOL..summers are well over 100 here too.....so they see A LOT of heat...and 18,000-21,000 miles a year....thats more milage than some race trailers see in a lifetime....this set is going on 38K miles right now...still look good...edges are a little feathered from tight turns though...
And as you noticed first hand...my trailer already killed one F-350....now I'm trying to kill the F-450....
Re: Trailer tires...again [Re: Chassisman] #1787737
03/27/15 06:09 AM
03/27/15 06:09 AM
Anoka County, MN
Anoka County, MN
Yeah, ENCLOSED trailer tires suck. I pulled an open trailer, with P type tires for 25 years, and never had a problem. I changed them, 3 sets, at 25,000 miles. The higher pressure changeover, at this income level, would render the car dormant. I'll continue with my friend, Jok's tire choice, and change them every three years.
Re: Trailer tires...again [Re: Leigh] #1787738
03/27/15 12:04 PM
03/27/15 12:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Keep them covered from the sunlight when ever possible
that kills the tire more than the heat... run the
pressure at max
Re: Trailer tires...again [Re: MR_P_BODY] #1787739
03/27/15 03:26 PM
03/27/15 03:26 PM
Washington State
lorenr Offline
lorenr  Offline
Washington State
Trailer tires are a serious risk, but motor coach tires are every bit as dangerous, maybe worse. The motor coaches need them changed every six or seven years and the more they sit the shorter the life. My rig with 295 75 22.5 tires sees maybe 50,000 miles in that time. Funny thing is, over the road rigs get 300,000 miles or more because the tires are in use. Sitting causes the metal cords to separate from the rubber and that is bad.
Keep them at maximum recommended pressure. I'm not sure if ultraviolet deteriorates the rubber or not. My understanding is that ozone is the real culprit. 02 will oxidize anything, even people, which is partly why we also age.
Loren
Re: Trailer tires...again [Re: Chassisman] #1787740
03/27/15 05:30 PM
03/27/15 05:30 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
The key here is the G rating on those tires. It would be hard to tear those up. As you said, not cheap,but its probably worth it because it could be the last set of tires you have to buy depending on how much you race.
Re: Trailer tires...again [Re: OUTLAWSSAA] #1787741
03/28/15 06:33 PM
03/28/15 06:33 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
Went through my records. I also had good experience with Firestone Transforce tires. Little cheaper but got good milage and no blowouts.
Re: Trailer tires...again [Re: Chassisman] #1787742
03/28/15 07:44 PM
03/28/15 07:44 PM
Anoka County, MN
Anoka County, MN
Made in Canada.
