426 Hemi Rocker shaft springs - question
#1787401
03/24/15 04:49 PM
03/24/15 04:49 PM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
If I thought this through properly, the springs are there to push the rockers against the rocker stand and to keep them from moving back and forth on the rocker shaft. I am also thinking that springs are used so that you could access the valve springs without removing the rocker shafts (which may require loosening head bolts). I am guessing there is enough compression in spring (I haven't assembled my heads yet) to get adequate access. I think I am correct in this thinking.
So another thought I had was this. If you had a sleeve that could be removable to be able to slide the rocker over, would it not be more desirable than the spring? Of course you would need to be certain that any of the parts used to secure a two piece sleeve would not come loose and fall into engine. But, in theory, would it not be more preferential to have a spacer that could dial in rocker arm side clearence?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: 426 Hemi Rocker shaft springs - question
[Re: RoadRunner]
#1787402
03/24/15 04:51 PM
03/24/15 04:51 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: RoadRunner]
#1787407
03/25/15 12:20 PM
03/25/15 12:20 PM
an8sec70cuda
I just use springs on mine.
