426 Hemi Rocker shaft springs - question #1787401
03/24/15 04:49 PM
03/24/15 04:49 PM
East Aurora (Buffalo) NY
RoadRunner Offline OP
If I thought this through properly, the springs are there to push the rockers against the rocker stand and to keep them from moving back and forth on the rocker shaft. I am also thinking that springs are used so that you could access the valve springs without removing the rocker shafts (which may require loosening head bolts). I am guessing there is enough compression in spring (I haven't assembled my heads yet) to get adequate access. I think I am correct in this thinking.
So another thought I had was this. If you had a sleeve that could be removable to be able to slide the rocker over, would it not be more desirable than the spring? Of course you would need to be certain that any of the parts used to secure a two piece sleeve would not come loose and fall into engine. But, in theory, would it not be more preferential to have a spacer that could dial in rocker arm side clearence?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 426 Hemi Rocker shaft springs - question [Re: RoadRunner] #1787402
03/24/15 04:51 PM
03/24/15 04:51 PM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 426 Hemi Rocker shaft springs - question [Re: an8sec70cuda] #1787403
03/24/15 05:43 PM
03/24/15 05:43 PM
Maryland
gofastboater Offline
Maryland
Get rid of the springs and go to the collars. Less wear and tear on the stands and rockers.
Re: 426 Hemi Rocker shaft springs - question [Re: RoadRunner] #1787404
03/24/15 08:58 PM
03/24/15 08:58 PM
I think Stage V and Keith Black both offer the proper size collars with a spring steel waffle (not flat, has a curve from the middle out as well as a S in it)shim to prevent the collar from rubbing on the rocker arms Thats the hot set up for all shaft mounted adjustable rocker arms as far as I'm concerned, way better than springs
Re: 426 Hemi Rocker shaft springs - question [Re: an8sec70cuda] #1787405
03/24/15 09:50 PM
03/24/15 09:50 PM
like this...
http://www.ebay.com/itm/Early-Hemi-Rocke...tr#ht_48wt_1153
Yeah. Something like that! Not sure if I will buy. I have everything set up for the springs.
2023 Ford Mach 1
Re: 426 Hemi Rocker shaft springs - question [Re: RoadRunner] #1787406
03/25/15 12:17 PM
03/25/15 12:17 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
like this...
That's what I use
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 426 Hemi Rocker shaft springs - question [Re: RoadRunner] #1787407
03/25/15 12:20 PM
03/25/15 12:20 PM
I just use springs on mine.
CHIP
