Re: Steering issue...
[Re: Bdrainy]
#1787321
03/24/15 03:29 PM
03/24/15 03:29 PM
Posts: 797 WA
pro451bee
WA
Raise it up in the front and place jack stands under the lower control arms , un lock the steering wheel , engine off ,then by hand swing the front tires full left and full right . This should be fairly easy. If you come to a bind in the system, look at oil pan to center link rub , also look at headers to linkage rubbing.My car the clearance is close at oil pan and the grease zerk on the LH inner tie rod rubbed the header. Next , if this checks out OK ,but a bind is felt , loosen the steering column at the fire wall and re test ,the column will move around alot at this juncture. I've seen a misalignment in the column to gear box cause a significant bind in the steering system .
[Re: RapidRobert]
#1787322
03/24/15 03:32 PM
03/24/15 03:32 PM
Posts: 512 Sacramento, CA
Bdrainy
Sacramento, CA
but here is the weird part. If I turn the steering wheel to the right while I am reversing, it feels pretty normal. Throw some ideas at my guys...please!
(1) expound on that a bit (more) I ain't grasping that (the reversing).
When I am backing out of my driveway or parking spot and turning the steering wheel to the right...there is no increased effort. It seems the problem is only when the car is sitting still or moving forward. It has me baffled!
[Re: Bdrainy]
#1787323
03/24/15 03:37 PM
03/24/15 03:37 PM
RapidRobert
As Sherlock Holmes would say, there has to be a clue. Rack your brain (again) for something that you are doing different between the forward/reverse exercises: pump speed (tho you'd think that'd be a both sides deal)
[Re: RapidRobert]
#1787325
03/24/15 03:45 PM
03/24/15 03:45 PM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
When driving forward the caster is causing the tire to return to center. When backing out the caster is working the opposite and is causing the tire to turn. Hence the reason it seems to be power assisted when backing and not going forward. Just an FYI
[Re: IMGTX]
#1787326
03/24/15 03:46 PM
03/24/15 03:46 PM
Challenger 1
Cincinnati, Ohio
Just an FYI
[Re: IMGTX]
#1787327
03/24/15 03:51 PM
03/24/15 03:51 PM
Bdrainy
Sacramento, CA
Just an FYI
That answers that question! Thanks!
[Re: RapidRobert]
#1787328
03/24/15 03:54 PM
03/24/15 03:54 PM
Bdrainy
Sacramento, CA
I really can't think of anything else...
I assume (usually a mistake) that the firm feel box is good and adjusted properly since I sent it back to them. I will check again for any binding while turning when I get home tonight.
But everything is somewhat leading me to the power steering pump...
Either that...or there is something that I am blatantly missing.
[Re: Bdrainy]
#1787329
03/24/15 04:09 PM
03/24/15 04:09 PM
RapidRobert
Yeah I'm thinking the box is good (they checked it out & certainly dont to deal with a double comeback on it so likely it is right). I'd think the pump is OK (if it wasn't it'd affect both sides). I'm thinking as others said something somewhere up front is changing/binding but what. You know, what I just thought of is I'd have a helper slide on a creeper on the ground with hood up & eveball up there as you slowly moved the car forward/backward & turned the wheel (safely of course/good help is hard to come by). Do holler how it turns out
[Re: Bdrainy]
#1787336
03/29/15 12:30 AM
03/29/15 12:30 AM
RapidRobert
You know I had an idea , I would lower the front till the wheels just touch & see if it still effortly goes lock to lock then lower it slightly more & repeat. Grab a helper.
[Re: captaindodge]
#1787338
03/29/15 08:35 PM
03/29/15 08:35 PM
Posts: 5,913 ohio
ruderunner
ohio
Have you tried: on the ground, engine off? Is the steering still wonky? If so something in the suspension is binding. If not the problem is most likely the box. It can't be the pump since that would affect both directions. Long shot, bad motor mount allowing the header to hit the center link or steering shaft? The engine would be torqueing over when in gear, opposite when backing.
Angry white pureblood male
