Info on Indy oil pump cover cleareance #1786737
03/23/15 05:36 PM
03/23/15 05:36 PM
Sth.IL
dare_dude Offline OP
Sth.IL
Put one on 499 looks like single oil line/fitting will hit steering gear box mount on my 68 Dart. Do any of you folks have suggestions? Pics would help also. Thought it had enough room since the mount was cl before but???
Re: Info on Indy oil pump cover cleareance [Re: dare_dude] #1786738
03/23/15 09:22 PM
03/23/15 09:22 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Not an A body but on my 73 Cuda I had to remove almost all of the motor mount. The Indy oil pump is very big.
Ok
Re: Info on Indy oil pump cover cleareance [Re: cudatom] #1786739
03/24/15 12:44 AM
03/24/15 12:44 AM
Sth.IL
Sth.IL
Friend of mine came over ground on it got some clearance.
