1970 Voltage Regulator Stamping #1786662
03/23/15 03:38 PM
03/23/15 03:38 PM
Ohio
RestoreCuda Offline OP
Ohio
I still have the original functioning voltage regulator for my 70 Cuda. Unfortunately the stamped label on it has worn off and needs restored. Does anyone make a stamp that I could use to restore my original regulator?
Re: 1970 Voltage Regulator Stamping [Re: RestoreCuda] #1786663
03/23/15 04:56 PM
03/23/15 04:56 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
A 70 V. Regulator wouldn't have a label that can fall off. They are ink stamped.
Ron
Re: 1970 Voltage Regulator Stamping [Re: RJS] #1786664
03/23/15 05:41 PM
03/23/15 05:41 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
A 70 regulator has a dime size outward bump on the face of it.None of the reproductions have that.
Re: 1970 Voltage Regulator Stamping [Re: RestoreCuda] #1786665
03/23/15 05:52 PM
03/23/15 05:52 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I took mine to a silk screen shop, and had them silk screen the logo on it.
Re: 1970 Voltage Regulator Stamping [Re: 71birdJ68] #1786666
03/23/15 06:25 PM
03/23/15 06:25 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
ECS sells a kit to re-stencil it.
Re: 1970 Voltage Regulator Stamping [Re: 70440+6bbl] #1786667
03/23/15 11:14 PM
03/23/15 11:14 PM
Ohio
Ohio
Thanks for the input. Greatly appreciated.
Re: 1970 Voltage Regulator Stamping [Re: RestoreCuda] #1786668
03/23/15 11:41 PM
03/23/15 11:41 PM
Jackson, Mississippi
CornDogsCharger Offline
A few years back, when I was restoring a 440 6bbl Superbird, I got lucky enough to find an older aftermarket Niehoff voltage regulator that was correct in appearance.... AND IT STILL WORKED! I cleaned it up, painted it, and had a local stamp company make an rubber ink stamp. Instead of using ink, I thinned out white paint and stamped it onto the freshly painted regulator. As you can see, I practiced a lot before I felt confident enough to stamp the regulator. They were never perfect, so I think it turned out great.
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
