ACC Boss Hog Converters #1786348
03/23/15 01:01 AM
03/23/15 01:01 AM
Denison,Ia.
Cuda367 Offline OP
Cuda367  Offline OP
Denison,Ia.
Looking for input on them.
Re: ACC Boss Hog Converters [Re: Cuda367] #1786349
03/23/15 01:29 AM
03/23/15 01:29 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I had one of the cheaper ones in my built up 904 with my 360 with 6 bbl Barracuda. It sucked bigtime ! Not enough stall, and came apart in less than 1000 miles, and shed metal throughout my transmission. I had only put it in to replace my Turbo Action converter that I felt was too loose.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: ACC Boss Hog Converters [Re: doctor_mopar] #1786350
03/23/15 01:38 AM
03/23/15 01:38 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
They were cheap in the 80's any tran that had them, they had over 80% failure. Someone was always complaining. Always recommend a brand name and the combo you use for engine car and gear.
Re: ACC Boss Hog Converters [Re: Mopar-Al] #1786351
03/23/15 02:38 AM
03/23/15 02:38 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I also had one come apart and spread aluminum throughout my transmission. This was behind my 13-second 383. I sent it back and they rebuilt it. It seemed okay after that, and actually performed pretty well behind the 383. But, when I put it behind the 451 and put a heavier dose of torque to it, it ballooned emediately and caused potentially serious issues. I ended up having to pull the motor to address thrust bearing issues. After these two issues, I junked it and opted to to spend the money on a good converter.
Now, I do have another buddy that runs one in his Dart. Less weight and less torque (12.30 car). It seems to be standing up okay in his application.
I'd be leary of using one behind anything that is going to see the drag strip. Street only, 13-14 second type car is where I'd draw the line.
Re: ACC Boss Hog Converters [Re: StealthWedge67] #1786352
03/23/15 03:52 AM
03/23/15 03:52 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I blew one up behind my 408 small block in a 93 dakota and a 904 trans. The stator got mad at me and tried to leave, lucky the flexplate and converter case kept it in place.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: ACC Boss Hog Converters [Re: slammedR/T] #1786353
03/23/15 11:50 AM
03/23/15 11:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Did a search on "George Reynolds" (GER fame) and it came up with Precision Converters and transmission..... so if you're looking for cheap krap that fails it appears to be still available.
Re: ACC Boss Hog Converters [Re: J_BODY] #1786354
03/23/15 11:59 AM
03/23/15 11:59 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I have been running one in my Mustang for several years. (10.40's at 130) I bought it used and it has worked well. Supposed to be a 4000, but it stalls at 4800 in my car. I have no complaints other than the fact it does not have anti-balloon plates. YMMV though.
I will probably be replacing it with one that does have plates since the new motor should make more steam and I have considered throwing a small shot on it just for giggles.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: ACC Boss Hog Converters [Re: J_BODY] #1786355
03/23/15 06:07 PM
03/23/15 06:07 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
GER
Pal of mine with a Nova put one in his car.
Turned a 13 second ride into a 14 second turd.
Re: ACC Boss Hog Converters [Re: B5 Bee] #1786356
03/23/15 09:11 PM
03/23/15 09:11 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
GER
"GER" and "Precision" shouldn't be used in the same sentence.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: ACC Boss Hog Converters [Re: DusterDave] #1786357
03/23/15 09:51 PM
03/23/15 09:51 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
have a friend who bought a 10 in G.E.R. about 1985 from jegs for 239 bucks and it is still in the car, a big block challenger.11 second car.flashes to 4200 and works well for what it is,must have been the prototype or the only one done right.maybe he should donate it to the smithsonian............
SFI 25.5 depends,no leak,even at 213 mph....
Re: ACC Boss Hog Converters [Re: dakotawilly] #1786358
03/23/15 10:39 PM
03/23/15 10:39 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
My old Demon started out with a $225.00 GER 3500 convertor ran a best of 7.38 in the 1/8. People was telling me I need to by a good convertor so I paid $600.00 for a Coan Race convertor and it lost over a tenth in the 1/8. Boy was I mad I wasted $600.00.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: ACC Boss Hog Converters [Re: D-50] #1786359
03/23/15 11:29 PM
03/23/15 11:29 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I'd still like to smack my $557 out of George's head. I call to ask him why my new converter turned the fluid black immediately and feels like a stock 1500 stall converter, he told me to go $%^& myself and hangs up on me. I was young so that was alot of money to me back then.
Re: ACC Boss Hog Converters [Re: Cuda367] #1786360
03/23/15 11:48 PM
03/23/15 11:48 PM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
Don't waste your money. I screwed up and bought one off eBay. 3000 stall that might have flashed 2300. With less than 300 miles trans acted funny would get hot quick etc. I put the stock one back in. Not that it matters 904 trans.
Save up and buy a name brand.
