oil pump mounting on a small block #1786339
03/23/15 12:51 AM
03/23/15 12:51 AM
Kentucky
71blackdemon Offline OP
Kentucky
the main cap where the oil pump drive sets down into is halfway broke out will that cause a problem. it still mounts okay but i didn't no if it would cause a problem on my small block thanks.
Re: oil pump mounting on a small block [Re: 71blackdemon] #1786340
03/23/15 01:28 AM
03/23/15 01:28 AM
md
mopars4ever Offline
mopars4ever  Offline
md
have a pic?
Re: oil pump mounting on a small block [Re: mopars4ever] #1786341
03/23/15 01:54 AM
03/23/15 01:54 AM
I wanna say OK but yes a pic is needed. (slightly) Off topic: have the pump bolts very likely snugged/turn eng right side up then insert the intergear to dead on align the pump then tighten/torque the 2 pump mounting bolts
