Uhhhh.......is this a bad sign? #1785847
03/22/15 06:16 PM
03/22/15 06:16 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
FINALLY got the intake off my Dakota to install the Hughes kit. This is what I found......
Isn't all of this supposed to be dry?
The gasket for the plenum didn't look bad, but, the front manifold gasket looked bad.
John
Re: Uhhhh.......is this a bad sign? [Re: SattyNoCar] #1785848
03/22/15 09:31 PM
03/22/15 09:31 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
That's common, those plenum gaskets are notorious for leaking.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Uhhhh.......is this a bad sign? [Re: gregsrt] #1785849
03/23/15 01:54 PM
03/23/15 01:54 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
normal,bust out the purple stuff
Re: Uhhhh.......is this a bad sign? [Re: d-150] #1785850
03/23/15 02:03 PM
03/23/15 02:03 PM
Purple stuff didn't phase it, had to break out the oven cleaner, and even that took multiple hits.
The underside of the throttle body was coated too. TB cleaner spray did nothing. Ended up pulling all the sensors off the TB and hitting that with oven cleaner too.
The stuff was thick in spots. I would have preferred to hot tank the intake, but, no service like that close by. I did the best I could with what I had to work with.
I spent more time trying to get everything clean than I did tearing it down.
John
Re: Uhhhh.......is this a bad sign? [Re: SattyNoCar] #1785851
03/23/15 02:23 PM
03/23/15 02:23 PM
dogdays Offline
dogdays  Offline
Carb cleaner?
What you're seeing could be reversion. My SHO motor's runners looked a lot like that after 124K miles, and it too is a dry intake.
R.
