Cummins Diesel 101 #1785662
03/22/15 01:54 PM
03/22/15 01:54 PM
West Palm Beach, Florida
Copper Dart Offline OP
To you Diesel guru's.
I purchased a '96 3500 auto with the Cummins Diesel and I would like some advise on performance up-grades. I will be using it primarily to tow a 28' enclosed car trailer with the occasional home owner run to the hardware store.
From stock, what would be the best order in minor modification to be done without greatly affecting reliability, drivability and fuel mileage? I've heard of sliding the fuel rail forward and i don't know what that means. I know next to nothing about Diesel engines so remember that when giving your answers.
What would be the mod's and in what order would you perform them in?
Thanks in advance.
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Cummins Diesel 101 [Re: Copper Dart] #1785663
03/22/15 02:00 PM
03/22/15 02:00 PM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
Google 12 valve performance paths, you will find a bunch of write ups on several forums. That is the best way to do it. Start with maintenance items first, then guages. Your weak link is the auto trans, those don't work from the factory so expect to spend $3-5k on a trans first
I have a 95 12 valve nv4500 in a 90 Ford F350 my fuel plate is slid forward and I have Bosch 250 or 275 injectors (can't remember) a long time. In this trim I 30PSI of boost and can haul 10k up a hill in 4th gear at speed.
Re: Cummins Diesel 101 [Re: Copper Dart] #1785664
03/22/15 02:20 PM
03/22/15 02:20 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I had a '96 Cummins auto, that's why I have my '01 six speed. Go mild on the upgrades, 300 hp should be about all a virtually stock transmission will live with.
Start here:
http://www.tstproducts.com/tstpowerkitwithoutvideowithkdpkit.aspx
Add a Transgo TFOD-HD2 shift kit and a tighter converter and call it good.
Give Mark at TST a call, he'll walk you through it all.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Cummins Diesel 101 [Re: Copper Dart] #1785665
03/22/15 10:02 PM
03/22/15 10:02 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Thanks in advance.
Copper
I've had a 1995 3500 since new. When new it wouldn't pull my 26" trailer up a steep hill on the interstate over 58mph. After these mods It'll go 70+ up any hill pulling my loaded 32 tri-axle, 64 Belvedere and a slide in camper Gross weight is around 19500lbs
Get one of these
http://www.ebay.com/itm/5-9L-Dodge-Cummins-Diesel-Fuel-Torque-Plate-10-10-/271797514447
And a pair of these
http://www.ebay.com/itm/PacBrake-Governor-Spring-Kit-94-98-Cummins-5-9L-12V-HP10029-/281424659884
Then cut the front of the air box open as it's opening is to small, stock filter element seems to work fine. Turn the boost to 30-35 psi. Finally have the pump timing set to 16 degrees. Depending on how far you slide the plate it will smoke some. Fuel millage will not suffer. Performance will be night and day. Mines been like this for years. 190K no issues.
Re: Cummins Diesel 101 [Re: Copper Dart] #1785666
03/22/15 10:15 PM
03/22/15 10:15 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
yes gov springs
slide stock plate forward
install a transgo tfod-diesel shift kit
330,000 mi on my auto so far !
also a switch to lock the converter is handy an only about $10.00.
Re: Cummins Diesel 101 [Re: calrobb2000] #1785667
03/22/15 11:29 PM
03/22/15 11:29 PM
it has a overdrive button. Is this what you mean?
How hard is it to slide the fuel plate? is that the one with the break off screw that you tap a torx bit into? i dont want to destroy the transmission with too much mods.
Mom.
Ricky Valdes
Re: Cummins Diesel 101 [Re: Copper Dart] #1785668
03/22/15 11:42 PM
03/22/15 11:42 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
He means this switch, an add on.
http://www.tstproducts.com/Torque%20Converter%20Lockup%20Switch.pdf
My truck was built in November 1995, I NEVER could get a dealer to reflash my computer. I think I was the first one to bring this issue to Mark's attention, had many conversations with Mark about upgrades and transmissions.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: Cummins Diesel 101 [Re: Copper Dart] #1785669
03/23/15 12:51 AM
03/23/15 12:51 AM
STL
cdstl Offline
cdstl  Offline
STL
I'm new to the Cummins myself for around 3 months now. The auto trannys do not like much more power than stock. They can be upgraded though.
In my opinion, this is the Moparts of the Cummins world...
http://www.cumminsforum.com/forum/
Another good one, just take your pick...
http://www.dieseltruckresource.com/forums/
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Cummins Diesel 101 [Re: cdstl] #1785670
03/23/15 01:48 PM
03/23/15 01:48 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
another for tst.there website has directions sliding fuel plate,also the kdp fix
Re: Cummins Diesel 101 [Re: d-150] #1785671
03/25/15 10:47 AM
03/25/15 10:47 AM
Throttle cable frayed, is this part of a recall?
Mom.
Ricky Valdes
Re: Cummins Diesel 101 [Re: Copper Dart] #1785672
03/25/15 11:02 AM
03/25/15 11:02 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
It was
http://dodgeram.info/tsb/recalls/970.htm
Robert
'69 300 Convertible
'16 300 S Hemi
Re: Cummins Diesel 101 [Re: 3hundred] #1785673
03/26/15 09:52 AM
03/26/15 09:52 AM
Recalls expire?
Mom.
Ricky Valdes
Re: Cummins Diesel 101 [Re: Copper Dart] #1785674
03/26/15 11:02 AM
03/26/15 11:02 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Your local dealer can tell from your vin number if all recalls have been done or not. I don't think they expire but i could be wrong.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Cummins Diesel 101 [Re: Savoy1964] #1785675
03/30/15 03:43 PM
03/30/15 03:43 PM
Correct. Recalls don't expire.
Called ma mopar and both throttle cable and headlamp switch recalls are outstanding on my vin. Parts have been expedited by ma Mopar Recall Center and I will be notified by my local Dodge truck dealer. Everything is on backorder. Some guy are selling the recall part on fleabay for upwards of $50 when it can be purchased (when in stock) from your local Dodge store for about $13.00. Hence the name "fleabay"
Thanks.
Mom.
Ricky Valdes
