Vacuum pump hookup #1785598
03/22/15 12:41 PM
03/22/15 12:41 PM
Ontario,Canada
1967GTX440 Offline OP
Ontario,Canada
This is what I want to do I am installing a vacuum pump as I now have the car so it will go so now I want to stop. I am thinking about hooking it up to the brake light switch any reasons why I should or should not do this .
Thanks in advance for any info.
Re: Vacuum pump hookup [Re: 1967GTX440] #1785599
03/22/15 12:51 PM
03/22/15 12:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Unless you are fabbing a setup yourself, do what the instructions say to do.
You want vacuum in the booster BEFORE you touch the brakes, so hooking it up to the brake lights is a bad idea.
Just power it by a keyed source and use a vacuum switch to turn it on and off on the ground side (might need to go thru a relay to protect the switch from too much current).
Don't be the exception.
