E body bucket seat core frame interchange? #1785590
03/22/15 12:35 PM
03/22/15 12:35 PM
Norway
cudaerik Offline OP
cudaerik  Offline OP
Norway
Is the 1970 cuda bucket seat core frame the same as on a 1970 Challenger with bucket seats?
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: E body bucket seat core frame interchange? [Re: cudaerik] #1785591
03/22/15 12:45 PM
03/22/15 12:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes, but be sure they are 1970 frames. I have seen some 71 style frames that people have put the 1970 upholstery on.
Make sure that the backs have the 1970 style release button.
Re: E body bucket seat core frame interchange? [Re: Alaskan_TA] #1785592
03/22/15 01:01 PM
03/22/15 01:01 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
From what I have seen, the seat styles between 70, and 71 was changed mid year of the 71 model, I think in December.
Re: E body bucket seat core frame interchange? [Re: Alaskan_TA] #1785593
03/23/15 02:04 PM
03/23/15 02:04 PM
pa.
dan9 Offline
dan9  Offline
pa.
What is the difference between 70 and 71 seats? Does the 71 have the foam backrest instead of springs like the 72 and up?
Re: E body bucket seat core frame interchange? [Re: dan9] #1785594
03/23/15 02:12 PM
03/23/15 02:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The latch changed. The 1971 style has a box welded to the side for the newer style button & retainer.
The spring style was used from 1970 into some point in the 1972 model year.
Re: E body bucket seat core frame interchange? [Re: Alaskan_TA] #1785595
03/23/15 02:31 PM
03/23/15 02:31 PM
pa.
dan9 Offline
dan9  Offline
pa.
Thank you.
