1973 Coronet Charger interchange #1785342
03/22/15 12:01 AM
03/22/15 12:01 AM
Naperville, IL
TamrazsParts Offline OP
Naperville, IL
long time mopar guy here. Mostly an a-body guy and have owned years of 1966-1970 b-body cars.
That said, I bought a great clean 1973 coronet custom that is all original paint. I'm just wondering if there is interchange between 1973-1974 charger bumpers and or grill.
I'd like to put a power bulge hood on the car, but was wondering what might fit otherwise.
Appreciate any experience you can all share on fitment. I know I can get charger seats and a center console to fit the car although the bench is quite comfy.
Come check out our latest products!
http://www.tamrazs.com
Re: 1973 Coronet Charger interchange [Re: TamrazsParts] #1785343
03/22/15 03:06 AM
03/22/15 03:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The externals are all different I'm pretty certain. The coronets are 4 doors no?
Re: 1973 Coronet Charger interchange [Re: buildanother] #1785344
03/22/15 10:46 AM
03/22/15 10:46 AM
dart1962_440 Offline
I have a 73 Coronet wagon. When I bought it, the guy threw in a Charger fiberglass hood - it's a lot longer.
The peak in the middle and the general taper to it (side to side from bumper to cowl) looked like it would work if the hood was shortened.
Re: 1973 Coronet Charger interchange [Re: dart1962_440] #1785345
03/22/15 04:31 PM
03/22/15 04:31 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
I have never official investigated this, but, if you found/had a complete 73-4 Charger front clip it might bolt on to the Coronet cars. Even then you would still have some funky body lines at the fender/door joint. It would look great if it worked.....
