489 Case bearing cap torque? #1785258
03/21/15 11:12 PM
03/21/15 11:12 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Dismantled the 489 case 3.91 open gears I have to install a clutch pac today.
Three things...
Whats the torque spec for the bearing caps for reassembly?
Whats the torque spec for the LH thread ring gear bolts?
Finally what would be the best backlash setting for something that is for the street but will see a small amount of track time?
Thx all...
...FAFO...
Re: 489 Case bearing cap torque? [Re: skicker] #1785259
03/21/15 11:15 PM
03/21/15 11:15 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Can't help with all of them ,but was always told the LH ring gear bolts were 55 ft lbs...
Re: 489 Case bearing cap torque? [Re: skicker] #1785260
03/21/15 11:20 PM
03/21/15 11:20 PM
Kirkland, Washington
Pacnorthcuda Offline
Bearing caps...90 ft lbs
Ring gear 55 ft lbs
Back lash .006-.009 And I would err closer to 009 than 006.
Re: 489 Case bearing cap torque? [Re: Pacnorthcuda] #1785261
03/22/15 12:18 AM
03/22/15 12:18 AM
Ring gear 55 ft lbs
That is what the 1969 Dodge F.S.M. calls for on the torque OP, the ring gear bolts are normally a one time use application and throw them away from Mopar, I cheat and reuse them and add some blue locktite to replace the stock factory locking compound
Re: 489 Case bearing cap torque? [Re: Cab_Burge] #1785262
03/22/15 12:19 PM
03/22/15 12:19 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
That works...I have this set-up for myself and another member to assemble Wednesday. Now just waiting for the box of parts from Cass and I'll be good to go. Thx for help...
...FAFO...
