Moroso Electric Waterpump S.B problems #1785215
03/21/15 09:15 PM
03/21/15 09:15 PM
ont,canada
mopartuner Offline OP
ont,canada
The problem I have is that if I use a 1-3/4 hose adapter on the bottom of the water pump it directs the hose right into the path of the alternator belt.I cant switch it to the drivers side on the car I am working on (power steering pump).The threads on the bottom of the pump angle the hose adapter towards the front.Has anyone else run into this?Is the best fix to use AN hose adapter and a 45 or 90 deg hose end?
410 pump gas solis flat tappet cam 10.95 so far
Re: Moroso Electric Waterpump S.B problems [Re: mopartuner] #1785216
03/21/15 10:18 PM
03/21/15 10:18 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I have the same pump, but I have a motor plate & my alt is low on the drivers side. Try the stainless flex hose. You might be able to run it under ur belt.
Re: Moroso Electric Waterpump S.B problems [Re: mopartuner] #1785217
03/21/15 11:42 PM
03/21/15 11:42 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Found a pic if this helps.
Re: Moroso Electric Waterpump S.B problems [Re: mopartuner] #1785218
03/22/15 12:39 AM
03/22/15 12:39 AM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Use napa radiator hose 7452,or gates # 20674 it works like a champ.
Re: Moroso Electric Waterpump S.B problems [Re: mopartuner] #1785219
03/22/15 12:53 AM
03/22/15 12:53 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Had the same problem. I just put a longer belt on. The alternator swings up then just enough to barely clear the belt/hose interference.
Yeah, it's got a smallblock.
Re: Moroso Electric Waterpump S.B problems [Re: 340B5] #1785220
03/22/15 10:45 AM
03/22/15 10:45 AM
ont,canada
ont,canada
Never thought of a longer belt.I will try it thanks.
Re: Moroso Electric Waterpump S.B problems [Re: WheelsUp73] #1785221
03/22/15 10:59 AM
03/22/15 10:59 AM
ont,canada
ont,canada
Looks like a wicked bend right by the pump....might work,I am going to order one,thanks
Re: Moroso Electric Waterpump S.B problems [Re: rickraw] #1785222
03/22/15 11:35 AM
03/22/15 11:35 AM
HR3128 Offline
HR3128  Offline
Sorry for the hijack.
But where did you get that tank?
Re: Moroso Electric Waterpump S.B problems [Re: HR3128] #1785223
03/22/15 12:00 PM
03/22/15 12:00 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Pm sent.
