anyone put a late model hemi in a 64-66 early A body. #1785116
03/21/15 08:01 PM
03/21/15 08:01 PM
Slidell, La.
doctor_mopar Offline OP
Slidell, La.
I am going to build a 64 Barracuda for someone. My first intent is to build a stroked 340/360 with 4 speed. However the thought of a late model Hemi has crossed my mind. In order for this to be a consideration financially it would need to be with stock/slightly modified K member and no excessive fabrication.This is a streetcar. Anyone been down this road ?
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: anyone put a late model hemi in a 64-66 early A body. [Re: doctor_mopar] #1785117
03/21/15 08:32 PM
03/21/15 08:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think you will need to do some measuring. If I remember the early A bodies are pretty narrow in the engine compartment.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: stumpy] #1785118
03/21/15 08:38 PM
03/21/15 08:38 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Re: anyone put a late model hemi in a 64-66 early A body. [Re: MuuMuu101] #1785119
03/22/15 07:56 PM
03/22/15 07:56 PM
Slidell, La.
Slidell, La.
Well, looks like it has been done with Alterkation front end ! I will not go that route. If I wanted to start with a coil spring front end, I would just tell the guy to buy a Chevrolet, and put an LS motor in it. I reckon to keep it all Mopar, I will just build the stroker LA engine for it.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: doctor_mopar] #1785120
03/23/15 01:12 PM
03/23/15 01:12 PM
dogdays Offline
dogdays  Offline
There was a board member who had connections with Chrysler. What he posted a few years ago is anyplace you can put a smallblock you can put a Hemi. No mention of need for different front end.
The Hemi has many advantages, one being it's 100 lb lighter than a stock 360. The power upside advantage is huge. Rods and pistons are much lighter so the engine will feel freer.
I am guessing that you may have to get creative in choosing exhaust manifolds. Also, the oil pan will require some digging to find the right configuration, unless you luck out with your engine purchase.
Still IMHO starting from Ground Zero the most sensible thing to do is go GIII Hemi.
R.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: dogdays] #1785121
03/23/15 01:40 PM
03/23/15 01:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I tried, no luck without cutting/fabricating. All the ex manifolds I tried were going to dump it right into the steering shaft or needed the inner fender cut out or... The best fit I could find on the pass side was a durango manifold and it would need the bumps around the control are bushings smashed in or cut out. Could not find any headers.
Oil pan would have been easy, the regular a body conversion pans out there should have fit.
I was going to run manual steering and no AC or power brakes so did not even try them.
For me the deal breaker was the exhaust, no way to do it without cutting.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: doctor_mopar] #1785122
03/23/15 05:20 PM
03/23/15 05:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did some rough measuring a few years back on a 65 Cuda with this very swap in mind. As HRD says, clearances around the UCA inner pivot is tight.
Tight enough that I dropped the idea.
Don't be the exception.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: HotRodDave] #1785123
03/23/15 11:47 PM
03/23/15 11:47 PM
Slidell, La.
Slidell, La.
That is what I wanted to know guys I have a buddy that could make it fit with whatever chassis work it would take. I just do not want to go to the trouble and expense. I can build a car that the customer will love and enjoy, with a traditional smallblock within his budget. Thank You !
Re: anyone put a late model hemi in a 64-66 early A body. [Re: doctor_mopar] #1785124
03/24/15 02:19 AM
03/24/15 02:19 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It's been done, aftermarket parts are available to do the swap correctly. The first thing you need to purchase is a wheel barrow to haul all the cash needed to do it.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: rowin4] #1785125
03/24/15 01:21 PM
03/24/15 01:21 PM
Slidell, La.
Slidell, La.
NO wheelbarrows of cash here ! I will just go with the stroker smallblock.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: doctor_mopar] #1785126
03/25/15 04:07 AM
03/25/15 04:07 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
You are way ahead in time, expense, & reduction of frustration with a small block - stroked or otherwise.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: ProStock1320] #1785127
03/25/15 04:25 AM
03/25/15 04:25 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
As I hate to admit it, I agree. A stock suspension early A is way difficult to throw a Hemi in. I'd imagine you'd have to have no accessories and manual steering. Heck, even throwing one in a stock suspensioned 67+ A body is a tight squeeze.
Re: anyone put a late model hemi in a 64-66 early A body. [Re: rowin4] #1785128
03/25/15 03:22 PM
03/25/15 03:22 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Care to tell us about an aftermarket (or factory) exhaust that can be made to work short of an aftermarket susspension or chopping up the body? Only way to do it would be custom headers.
