small block rod bearing part number for mopar stroker #1785059
03/21/15 07:12 PM
03/21/15 07:12 PM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
What is small block rod bearing part number for mopar stroker crank with radius journals? Cb481hn is too wide. Thanks Bradley
Re: small block rod bearing part number for mopar stroker [Re: roadrunnerreds] #1785060
03/21/15 07:31 PM
03/21/15 07:31 PM
P
Porter67 Offline
Porter67  Offline
P
Not sure why thats not correct, Eagle,K1 and others use that bearing. What rods, whats the crank PN?
Re: small block rod bearing part number for mopar stroker [Re: Porter67] #1785061
03/21/15 07:57 PM
03/21/15 07:57 PM
Gettysburg Pa
Gettysburg Pa
Scat I beam rod and mopar 4.00 cast crank.
Re: small block rod bearing part number for mopar stroker [Re: roadrunnerreds] #1785062
03/21/15 08:14 PM
03/21/15 08:14 PM
Gettysburg Pa
Gettysburg Pa
Believe it or not the notch in bearing it not constant therefore the it is NOT allowing rod to set against the crank side of the journal
Re: small block rod bearing part number for mopar stroker [Re: roadrunnerreds] #1785063
03/21/15 11:48 PM
03/21/15 11:48 PM
smyrna,tn
draginmopars Offline
smyrna,tn
ran into that before.
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: small block rod bearing part number for mopar stroker [Re: draginmopars] #1785064
03/22/15 09:19 PM
03/22/15 09:19 PM
P
Porter67 Offline
Porter67  Offline
P
Unless this is a big error on the QC dept it might be the uppers vs the lowers. I got to wondering and these are Mclevite and King brands and the uppers are slightly different then the lowers and I myself do assembly in stages and you can pretty much eyeball if you have a upper and lower in the wrong spot.
Yes I have missed it one time and knew right away as it creates a tight spot and you surpass your breakaway tq at that point so if its just two rods I had to go back and look at.
But in this day and age id not be surprised if some got mis stamped.
But it does look like Dragons are a bit off. Might be an easy fix if they are not too far off or id send the company a pic and ask for some correct bearing since you paid for them.
Re: small block rod bearing part number for mopar stroker [Re: Porter67] #1785065
03/23/15 04:20 AM
03/23/15 04:20 AM
Gettysburg Pa
Gettysburg Pa
Yes sir i did not notice upper and lower halfs. All good for now.LOL
