Re: 360 oil pressure
[Re: Lmopar69]
#1784984
03/21/15 04:24 PM
03/21/15 04:24 PM
Porter67
You failed to mention what weight oil? On the .0025-.003 builds with 30w I normally get over 75 on startup and over 30 at idle of 1000 rpm and hits 75 at any above, thats with the melling hv72 pump. Did you do the normal breakin and drain oil and cut filter for inspection? Im wondering what others will say.
[Re: Lmopar69]
#1784988
03/21/15 10:34 PM
03/21/15 10:34 PM
RapidRobert
I have the engine in a 2700 pound street/racecar with 29 inch tall tires and a 4.56 gear. I suspect I'll finish the quarter mile around 6000 to 6500 RPM. if memory serves the general rule is 10 PSI per 1000 RPM.
Thoughts?
Laine
Its too low. I'm assuming the 3/8 pipe plug on the rear end of the dr horizontle oil gallery is in place (the one that is hidden inside), & if the oil weight is correct (I ain't an oil guy) then as said pull the pump & see what is up with it. Holler with any developments. EDIT Direct reading gauge?
[Re: Lmopar69]
#1784991
03/22/15 01:39 PM
03/22/15 01:39 PM
RapidRobert
You might pull the dist/intergear & preoil (CW) with the 5/16 hex shaft & see what develops and the plug at the rear end of the dr horizontle oil gallery is straight down in the dist hole so you will be able to (easily) check that (visually) at the same time. if that is it it'd sure be a stroke of luck for you expecially if you can install it from the dist hole & I'll check mine later today. it'd take some doin but might be doable
