WOT - Backfire ?? #178485
12/29/08 09:55 PM
12/29/08 09:55 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
Hey Guy's after 4.5 years, I finally drove my truck. Although it's only a 400 I'm very pleased.
Have an issue tho.. Driving normal it's great under hard accel or short WOT it will pop out the exhaust, big puff of black and buck a little like the tranny is trying to shift then it goes on.
It's a 750 holley (off of my 440) with vacc. secondaries, auto tranny. Timing seems right on easy starts after it's been driven and warmed up. I set it at about 12* stock 400 with a comp cams xe256h cam. Any ideas about which way to go - Thanks
Re: WOT - Backfire ?? [Re: 67MIke] #178486
12/29/08 10:16 PM
12/29/08 10:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
check your total advance. I'd proabaly start at 36* @ 2500rpm. Also you really should tune the carb. Check the vaccum at idle and under load. turn the mixture screws all the way in and then out 1/4 turn. Adjust until you get the highest vacuum. Then re-set your timing full advance w/o the vacuume advance. Then re-set the carb again. It will take a few turns of the wrench.
Re: WOT - Backfire ?? [Re: Mr.Yuck] #178487
12/29/08 10:24 PM
12/29/08 10:24 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
Thanks -
On this dizzy, I don't have a vacuum advance, I think it came from a 78 or so fury or .... looked like a cop car...
Re: WOT - Backfire ?? [Re: 67MIke] #178488
12/29/08 10:29 PM
12/29/08 10:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Take your time, and walk away when you need to. It beats throwing wrenches down the street....
Re: WOT - Backfire ?? [Re: 67MIke] #178489
12/29/08 10:33 PM
12/29/08 10:33 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
Thanks -
has somebody taken the advance pot off and is the timing locked? its it a lean burn distributor?
i have seen a advance pot taken off and the block off plate screwed on. only prolem was the advance wasnt locked out so at full throttle the weights would just fly around causing some very strange backfires.
Re: WOT - Backfire ?? [Re: chrisf] #178490
12/29/08 11:09 PM
12/29/08 11:09 PM
Frankly I doubt it's timing. You might have a dodgy plug wire or even a damaged / broken plug or cracked/ tracked dist. cap.
You might have weak spark, caused by a number of issues, including resistance in wiring (poor connections,) a bad coil, bad capacitor if points, or bad cap (not replaceable) if you're using electronic (ECU) Poor ignition voltage--our world famous bulkhead connector.
Also, a bad cam lobe can cause popping on one or more cylinders
Re: WOT - Backfire ?? #178491
12/30/08 12:16 AM
12/30/08 12:16 AM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
Thanks - Seems to run great except for the wot - I will check all I can Though
Re: WOT - Backfire ?? [Re: 67MIke] #178492
12/30/08 01:27 AM
12/30/08 01:27 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
A couple of things to check..
a. Accelerator pump stroke, adequate clearance is required
b. Position/choice of accelerator pump cam
c. Mite need to bump up the nozzle size a step
Just my $0.02..
