Re: why is a challenger longer than a cuda
[Re: Moparnut426]
#1784828
03/21/15 01:43 PM
03/21/15 01:43 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
With identical engine / transmission / rear end combinations, the Barracudas have shorter drive shafts than the Challengers.
[Re: Alaskan_TA]
#1784829
03/21/15 01:44 PM
03/21/15 01:44 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
With identical engine / transmission / rear end combinations, the Barracudas has shorter drive shafts than the Challengers.
Was there a reason? Seems expensive to me to tool up 2 different Jigs for the E body line up...
[Re: 71birdJ68]
#1784831
03/21/15 02:33 PM
03/21/15 02:33 PM
Moparnut426
Back then Dodges always had a longer wheel base than a Ply. Every body style in a Dodge did. I think it went way back to when Plymouth was a cheaper car line.
I don't buy this as I know a Roadrunner/Gtx and a Coronet/Superbee are the same. I used a Roadrunner driveshaft in a Coronet before.
Atleast the one I sold the guy was out of a 69 RR and he stuck it in a 69 Bee.....
[Re: 71birdJ68]
#1784832
03/21/15 02:33 PM
03/21/15 02:33 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
Is that true? Very interesting. Even the A bodies?
[Re: Pacnorthcuda]
#1784834
03/21/15 02:38 PM
03/21/15 02:38 PM
Moparnut426
I just googled it some and I am seeing 116 wheelbase for the 69 belvedere, road runner, and 117 inches for the coronet, bee. A 1" difference would explain being able to swap a shaft.
I can see that, but I wouldn't want to put the longer one in the shorter car.... ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Pacnorthcuda]
#1784835
03/21/15 03:50 PM
03/21/15 03:50 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
Yes, but it is best to keep the u-joint closer to the transmission
[Re: topside]
#1784837
03/21/15 05:04 PM
03/21/15 05:04 PM
Pacnorthcuda
Stay on topic, not about driveshaft lengths! So are Darts longer than Valiants? If Dodges are longer across the model lines it does seem that Chrysler went to great lengths (pun intended!) to make this differentiation! Very interesting... ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Pacnorthcuda]
#1784840
03/21/15 05:48 PM
03/21/15 05:48 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
1958 Plymouth wheelbase is 118 inches
1958 Dodge wheelbase is 122 inches.
My car being a wagon, is on the longer dodge chassis.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Pacnorthcuda]
#1784841
03/21/15 06:07 PM
03/21/15 06:07 PM
BSB67
Prospect, PA
OP Question:
"Will drive shafts interchange?"
[Re: BSB67]
#1784844
03/21/15 06:14 PM
03/21/15 06:14 PM
Pacnorthcuda
OP Question:
Yea you're right, my bad.
[Re: Pacnorthcuda]
#1784845
03/21/15 06:51 PM
03/21/15 06:51 PM
Posts: 8,413 Highland, MI.
Sunroofcuda
Highland, MI.
Challenger trunk pan is longer too - a little more room in the Challenger trunk. You can see it.
[Re: Moparnut426]
#1784846
03/21/15 06:54 PM
03/21/15 06:54 PM
Posts: 711 San Francisco
dilvoy
San Francisco
Have always wondered this,
Is it the wheelbase alone? Will drive shafts interchange?
I always thought it for styling reasons to be able to use the curving shape of the main character line on the side of the Challenger and make it graceful.
