Re: Anyone used jegs a-body dual exhaust?
[Re: Limelight]
#1784775
03/21/15 01:21 PM
03/21/15 01:21 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
I just put one on my Demon. I have Hooker headers, but not the ones they specify to use with the kit. I also changed a few things, like added some cut outs and used the factory tips. If you have it exactly as they spec, it might be a true bolt on. I ended up cutting and fitting pieces to make it work, and actually had to use pieces in the incorrect position. Overall fit is probably about 6/10 on my application. I'd have been money ahead having an exhaust shop custom bend a system.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: Paul_Fancsali]
#1784777
03/21/15 06:44 PM
03/21/15 06:44 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I have the A-Body Jegs kit on my '89 Diplomat which has crate 360 and TTI Headers. The car did not come with dual exhausts, so I had to shift the gas tank over slightly to right, and extend fuel fill tube. A little modification was needed on driver's side (the stock single came out passenger side) where front seat mounts. Overall though, I would say it is a very nice kit and I have been happy with it. I got the kit without mufflers, and added Walker Quiet Flows.
Facts are stubborn things.
[Re: Limelight]
#1784778
03/21/15 07:21 PM
03/21/15 07:21 PM
Posts: 2,578 sweden
1Fast340
sweden
I was planning to buy a TTI dual exhaust for my 67 383 dart, but the Jeg's kit offers the same features and materials for about 500 less. Has anyone used the Jegs kit? It's designed to fit Hooker headers, but I'd be inclined to stay with tti headers....has anyone tried the jegs exhaust with tti headers? Thanks!
Not anywhere near the same features as a TTI system. No X or H pipe. Universal hangers instead of TTI´s OEM type hangers. Piece of crap flanges on the reducers(if reducers are included) Not made for headers with collectors that point inwards. Cheaper mufflers. Have seen pics of those systems installed and they are not anywhere near as nice fitting.
[Re: 1Fast340]
#1784779
03/22/15 02:56 AM
03/22/15 02:56 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
The Jegs/Summit exhaust are made by Heartthrob. While they are a third the price of TTi units, unless you e got the Hooker Super Comp headers, they won't come close to fitting with TTi headers. Ask me how I know... I was under my 70 Superbee tonight trying to get mine to fit. Everything from the mufflers back fit fine. Everything from the fronts of the mufflers to the headers is pretty useless. I ended up using my TTi collecter adapters, a pair of Walker 3" ID to 2 1/2" ID reducers, reversed the exhaust pipes end to end, cut them in two, added a Summit H pipe, tossed out two short pieces that go between the mufflers and exhaust pipes, stubbed the exhaust pipes to the mufflers and clamped it all together. I've got 14 hours into it. Never again.
I’m listening.
[Re: Big Bad Bee]
#1784780
03/22/15 08:51 AM
03/22/15 08:51 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I have used both the A-body and B-body systems. The B-body needed some minor tweaking but no problems at all with the A-body.
For a $500 difference I don't mind doing some tweaking.
"I think its got a hemi"
[Re: Big Bad Bee]
#1784781
03/22/15 11:17 AM
03/22/15 11:17 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
HTH is that relevant to an A body?
It's not.
[Re: Supercuda]
#1784782
03/23/15 01:36 AM
03/23/15 01:36 AM
Big Bad Bee
Spokane Valley, WA
It's not.
He said he's wanting to stick with TTi headers. the difference between super comps and TTi headers would be relatively the same between A to B body. Hookers are shorter and don't angle the same at the collector regardless, right? Everything I said about the heartthrobs fitting well from the mufflers back applies to A bodies as well.
That's how the hell it is relavant, thank you very much. p
I’m listening.
[Re: 1Fast340]
#1784784
03/24/15 08:21 PM
03/24/15 08:21 PM
Posts: 31 Jacksonville, FL
Limelight
Jacksonville, FL
Youre right I overlooked those differences. Good response, thank you
[Re: Big Bad Bee]
#1784785
03/24/15 08:26 PM
03/24/15 08:26 PM
Limelight
Jacksonville, FL
I imagine it will be pretty similar for the A body. Thanks for your input!
[Re: Limelight]
#1784786
03/25/15 03:17 PM
03/25/15 03:17 PM
Posts: 2,578 sweden
1Fast340
sweden
Worked for many years with exhaust and became sort of picky on details
I realize my reply might seem alitle harsh and want to add that i think the Summit/Jegs kits might be a fairly good value for what they are but i think the TTI kit is quite a few notches higher in my simple opinion
[Re: Limelight]
#1784787
03/25/15 03:25 PM
03/25/15 03:25 PM
Posts: 2,080 CA
crackedback
CA
No it won't.
I have three of these kits on A body cars. 2 cars with tti and they required some reworking of the headpipes. I also placed the mufflers on the car the way they are supposed to go which greatly reduced install issues.
