Idler Arm Issue? #178429
12/29/08 08:58 PM
12/29/08 08:58 PM
a cornfield near you
BlakDak Offline OP
BlakDak  Offline OP
So I picked up a vehicle and at 40 or so it would shake like mad from the passenger side. So I thought.
I get it home, get under it, everything seems tight. Lube up all the greasable fittings. Get the front wheels off the ground, no noticeable play.
I checked the wheel bearings, and they were a lil loose, probably need repacked, but tightened them up.
So I thought I would swap the right side tires from front to rear, and see if the shake moved or went away.
Get her all back together, and dang it, the wobble is now coming from the driverside!
So Idler Arm? The steering is a lil loose, but doesn't seem to wander.
The only thing I can think of is my buddy that was helping me swapped the front tires when I went to go get food. I left a message, but he has not called back.
Re: Idler Arm Issue? [Re: BlakDak] #178430
12/29/08 09:01 PM
12/29/08 09:01 PM
Toss that tire(s)
Re: Idler Arm Issue? [Re: RapidRobert] #178431
12/29/08 09:08 PM
12/29/08 09:08 PM
BlakDak Offline OP
BlakDak  Offline OP
Toss that tire(s)
uh what?
Re: Idler Arm Issue? [Re: BlakDak] #178432
12/29/08 09:38 PM
12/29/08 09:38 PM
tire/rim way out of balance or it's belts starting to seperate
Re: Idler Arm Issue? [Re: BlakDak] #178433
12/29/08 09:57 PM
12/29/08 09:57 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
That's probably it right there--your buddy is stuck between the wheel and brake drum.
Re: Idler Arm Issue? [Re: FuryUs] #178434
12/29/08 10:00 PM
12/29/08 10:00 PM
BlakDak Offline OP
BlakDak  Offline OP
update, he called back, didn't touch the wheels.
and no he's not stuck between them.
Re: Idler Arm Issue? [Re: BlakDak] #178435
12/29/08 10:49 PM
12/29/08 10:49 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I'd still go with it being a tire (or tires). I've personally seen tire wear act just like a bent rim. Try swapping the wheels front to back and try it out. I'm guessing you'll see a difference.
Re: Idler Arm Issue? [Re: 6PakBee] #178436
12/29/08 11:04 PM
12/29/08 11:04 PM
BlakDak Offline OP
BlakDak  Offline OP
I did that on the pass side, but not the driver, and some how it moved to the driver..... I'll swap the driver side in the morning.
I thought it might be the idler arm because the steering seemed loose, but then again I have been driving RnP cars daily for a while now.
Re: Idler Arm Issue? [Re: BlakDak] #178437
12/30/08 12:50 AM
12/30/08 12:50 AM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
Jack up the right side and grab the right wheel. Move it back and forth while the left is still on the ground see if you have any movement. If you do just look under the car when you are moving it. If it is the idler arm it will be obvious.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: Idler Arm Issue? [Re: 69superbee383] #178438
12/30/08 10:57 AM
12/30/08 10:57 AM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
If you are wanting to eliminate the wheel as an issue, move the front tires to the back and the back ones to the front. See if it's still there. I had a similar problem on my car, the lug holes were "wallered out" on one of my wheels according to my alignment guy. I put the spare on and the problem disappeared. Couldn't hurt to check the idler either.
Re: Idler Arm Issue? [Re: pyp1000] #178439
12/30/08 12:35 PM
12/30/08 12:35 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I hope that you know what you are doing when you say that you tightened up the front wheel bearings. Better too loose than too tight.
I go along with the guys on wheel balance.
Re: Idler Arm Issue? [Re: MoparforLife] #178440
12/30/08 02:32 PM
12/30/08 02:32 PM
michigan
tonycpe Offline
tonycpe  Offline
michigan
I had the same problem on my 1962 dodge back in high school.
Bad wheels and loose front end , fix acordingly and don't forget the shocks.
Old Fogey Racing Ltd.
Re: Idler Arm Issue? [Re: tonycpe] #178441
12/31/08 01:00 AM
12/31/08 01:00 AM
BlakDak Offline OP
BlakDak  Offline OP
move the driver side to the back, still there...:(
as far as tightening the wheel bearings, no, I didn't crank the nut down......
the nut was loose, when I pulled the cotter pin washer off it was spinning with it... if that makes sense.
I'll jack up one side tomorrow and wiggle things.
Re: Idler Arm Issue? [Re: BlakDak] #178442
01/02/09 07:01 PM
01/02/09 07:01 PM
BlakDak Offline OP
BlakDak  Offline OP
well with the drivers wheel on the ground, it was clear the outer driver side tie rod was shot.
thanx for the help guys
Re: Idler Arm Issue? [Re: BlakDak] #178443
01/02/09 07:42 PM
01/02/09 07:42 PM
North Dakota
North Dakota
Glad you found it.
