Re: Difference between H3 & H4C tranny
[Re: DartVader69]
#178424
12/30/08 05:37 PM
12/30/08 05:37 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When you say "stamped" do you mean raised casting numbers? Raised casting numbers are near useless for identifying a trans.
[Re: DartVader69]
#178426
12/30/08 09:08 PM
12/30/08 09:08 PM
John_Kunkel
Rio Linda, CA
If it's a Mopar trans built after '67 look for a machined raised pad on the passenger side of the case, near the front.
If it's not Mopar or earlier than '68 a pic would help.
[Re: DartVader69]
#178428
01/01/09 04:29 PM
01/01/09 04:29 PM
John_Kunkel
Rio Linda, CA
Number one has a partial VIN which is most common, number two has the full VIN which (I think) was only used in the '69 model year. They're both from '69 cars, number one is from a car built at the Lynch Road plant so it's from a B body. Number two is from a Dart built at the Los Angeles plant; the P engine designator is for the 340 and it should have a shorter tail housing which accounts for the difference in weight. More info: http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
