Hemi heads??
#1784115
03/20/15 01:37 AM
03/20/15 01:37 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
Can anyone tell anything about these heads from this one pic? What year, etc? TIA, Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Hemi heads??
[Re: MOBodyman]
#1784116
03/20/15 11:58 AM
03/20/15 11:58 AM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
Casting number would seem to indicate 66 to 71 426 Hemi.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Hemi heads??
[Re: MOBodyman]
#1784117
03/20/15 12:10 PM
03/20/15 12:10 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
They are "X" heads. Closest one looks like a 1968. The year wouldn't matter for you. Looks like old top fuel heads. Notice the plug tube seals and the 1/2" head bolts. If you flip them over you might see machining for receiver grooves for o-rings. On fuel they will crack first between the spark plug and the intake valve seat. If you keep running them they will crack between the spark plug and the exhaust valve seat. These are obviously old race parts and most likely not worth having.
2011 Drag Pak Challenger
Re: Hemi heads??
[Re: MOBodyman]
#1784119
03/20/15 12:51 PM
03/20/15 12:51 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
All the above is true concerning top fuel heads, however, that does'nt always make them junk. Small cracks between the spark plug and valves are not a huge deal to repair, in fact a lot of them will run just fine on mild street builds with the cracks left alone. Any good machine shop can check them out and give you a condition report (reccomended before purchase). If they have minor cracks, probably worth $500-$600.00, if not, probably $800-$1,100.00ish due to the bigger bolt holes. Also, concerning dates, the one being a Nov 1968, it most likey came off a 69 or later engine. ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Hemi heads??
[Re: ScottSmith_Harms]
#1784121
03/20/15 01:28 PM
03/20/15 01:28 PM
MOBodyman
Missouri
The wanted $650 for all three. I'm not a mechanic and certainly not knowlegable on hemi parts. If someone is interested pm me & I'll send the guy's phone #. Thanks for the help, Dallas
Re: Hemi heads??
[Re: MOBodyman]
#1784122
03/20/15 03:41 PM
03/20/15 03:41 PM
DaytonaTurbo
Manitoba, Canada
There's a reason they're so cheap. Your machinist is not going to like the way they look. I guarantee it.
Re: Hemi heads??
[Re: RUNCHARGER]
#1784124
03/21/15 05:31 PM
03/21/15 05:31 PM
Posts: 10,759 North Dakota
6PakBee
North Dakota
Years ago when there was nothing out there new but lots of used up race junk, I'd take a set of dye penetrant chemicals with me and DP them in front of the seller. There was more than one pair I did that looked like an alkali flat around the valve seats and between the valves and spark plug. You can't be too careful unless you want to collect door stops.
