Re: suggestions for v10 spark plugs
[Re: chargers777]
#1784106
03/23/15 03:38 PM
03/23/15 03:38 PM
Guitar Jones
Suggestions? Sure, put Champions in it, ten of them to be exact.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: chargers777]
#1784111
03/24/15 11:27 PM
03/24/15 11:27 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
the older truck V-10 is just a 5 cylinder magnum head, they are different from the viper motor v-10 and the newer srt ram v-10 motors(which is the same as the viper motor).
I run NGK 4291 plugs in the magnums and V-10 motor when "stockish"
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
