Re: suggestions for v10 spark plugs
[Re: chargers777]
#1784106
03/23/15 03:38 PM
03/23/15 03:38 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Suggestions? Sure, put Champions in it, ten of them to be exact.
[Re: chargers777]
#1784111
03/24/15 11:27 PM
03/24/15 11:27 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
the older truck V-10 is just a 5 cylinder magnum head, they are different from the viper motor v-10 and the newer srt ram v-10 motors(which is the same as the viper motor).
I run NGK 4291 plugs in the magnums and V-10 motor when "stockish"
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
