440 truck pan capacity #1784037
03/19/15 11:14 PM
03/19/15 11:14 PM
Ohio
O
Oldbracketracer Offline OP
O
Ohio
Can anyone tell me the capacity of the rear sump truck pan on a 440?I have one I am going to use on a bracket car with ground clearance restrictions.
Re: 440 truck pan capacity [Re: Oldbracketracer] #1784038
03/20/15 12:41 AM
03/20/15 12:41 AM
If no answer I'd Google it
Re: 440 truck pan capacity [Re: RapidRobert] #1784039
03/20/15 01:18 AM
03/20/15 01:18 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Pretty sure they were 6 qt capacity IIRC.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 440 truck pan capacity [Re: RapidRobert] #1784040
03/20/15 02:09 PM
03/20/15 02:09 PM
Ohio
O
O
Ohio
i already did that and got conflicting results (big surprise). Following up search results from sources that SHOULD be reliable left me with anywhere from 5 to 9 quarts. Seems to be many well informed people here so I thought a post here was worth a shot. I guess to be sure I will need to do some measuring.
Re: 440 truck pan capacity [Re: 71yelladustr] #1784041
03/20/15 02:11 PM
03/20/15 02:11 PM
Ohio
O
O
Ohio
This is what I am thinking as well. After I have a chance to do some measuring I will post findings. Thanks for the reply.
Re: 440 truck pan capacity [Re: Oldbracketracer] #1784042
03/20/15 07:57 PM
03/20/15 07:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Trucks were always 6 quarts with the filter. The dipsticks never were correct. From new at the dealership we would add 5 run it for a minute let it sit 1/2 hour and trim the tube as needed to read 1 quart low. Then add the 6th quart.
Re: 440 truck pan capacity [Re: NITROUSN] #1784043
03/21/15 05:04 PM
03/21/15 05:04 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
if running small filter it will take a little less, but big filter 6 quarts
Re: 440 truck pan capacity [Re: d-150] #1784044
03/21/15 06:42 PM
03/21/15 06:42 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
6 qt for the factory BB truck pans
Re: 440 truck pan capacity [Re: 440trk] #1784045
03/21/15 11:56 PM
03/21/15 11:56 PM
Ohio
O
O
Ohio
Thanks for the replies.
Re: 440 truck pan capacity [Re: 440trk] #1784046
03/22/15 01:05 AM
03/22/15 01:05 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Yep. My Mopar Performance one from Summit is a 6 qt pan.
Re: 440 truck pan capacity [Re: Triggerfish] #1784047
03/22/15 12:14 PM
03/22/15 12:14 PM
Renton, WA
GreenBlurr Offline
super gas
GreenBlurr  Offline
super gas
Renton, WA
Here is your pre-magnum trucks rule of thumb:
Small block: 6 quart total oil change.
Big block:6.5 quart oil change low deck and 7 quart tall deck. And if you are smart, you will run a proper big block filter on either one as they fit both.
Big block RV: ad 1/2 quart across the board.
Re: 440 truck pan capacity [Re: GreenBlurr] #1784048
03/23/15 02:19 PM
03/23/15 02:19 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
my factory 77 440 cannot run big filter .there is a pulley in front of it so depends on the pulley system u use
