FBO Distributor limiter plates
#1784032
03/19/15 11:12 PM
03/19/15 11:12 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. Anyone have experiences with the new FBO advance limiter plates? With this 426 Hemi I just put in the daytona, I'm finding out she's a different animal than my OEM 440. I am finding out the motor likes more than normal initial, but that obviously causes the total advance to be more. At the present time, I am using the Mr. G's light springs ( both ) and setting the timing to about 16 degrees. I have the vacuum connected to the pod as well. I am getting a total of nearly 40 with all this. The distributor doesn't advance without the vacuum when I rev it up to 2500 rpm. I am thinking as well I may be totally in already with the mechanical weights with the light springs and my need to go to replace one light spring with the smaller OEM spring. But, I like the theory of limiting the overall total with the plates while giving my motor as much initial timing as it likes..
thoughts?
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: FBO Distributor limiter plates
[Re: hemi68charger]
#1784033
03/19/15 11:19 PM
03/19/15 11:19 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
I put one in the 340 in the Duster, pretty slick deal if your not into welding the slots up. Goes in real easy and give you a chance to clean and inspect everything
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: hemi68charger]
#1784035
03/20/15 09:37 AM
03/20/15 09:37 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
It's simple and works, although I found the advance I measured was off slightly compared to what they had marked, maybe 2 degrees, I don't recall and don't have my notes in front of me.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: hemi68charger]
#1784036
03/20/15 10:16 AM
03/20/15 10:16 AM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
Hey gang.. At the present time, I am using the Mr. G's light springs ( both ) and setting the timing to about 16 degrees. I have the vacuum connected to the pod as well. I am getting a total of nearly 40 with all this. The distributor doesn't advance without the vacuum when I rev it up to 2500 rpm. I am thinking as well I may be totally in already with the mechanical weights with the light springs and my need to go to replace one light spring with the smaller OEM spring.
thoughts?
With both of the MR. G springs you'll all in by 1200. Try setting the timing @ 2500 with the vac. disconnected to about 35* then connect the vac. Your total then should be around 50 - 54*. don't worry about intial just set for total and see how it runs.
BTW I do like the idea of the FBO plate.
