Lakewood Scatter-shield Blockplate ID #15781 #1783134
03/18/15 09:46 PM
03/18/15 09:46 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline OP
P
What is the difference between these Lakewood Scattershield Blockplates? Both are for a small block 833, one has vents, the other doesn't. Both are stamped 15781. Which one to use?
I also noticed that there are 4 captivated nuts at the top of the plate w/the vents.
Re: Lakewood Scatter-shield Blockplate ID #15781 [Re: Pntastar69] #1783135
03/18/15 09:47 PM
03/18/15 09:47 PM
P
P
or this one?
Re: Lakewood Scatter-shield Blockplate ID #15781 [Re: Pntastar69] #1783136
03/19/15 02:43 PM
03/19/15 02:43 PM
P
P
Anybody?
Re: Lakewood Scatter-shield Blockplate ID #15781 [Re: Pntastar69] #1783137
03/19/15 02:51 PM
03/19/15 02:51 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Louvered one is older, flat one is newer. The latest version has larger bolts where the block plate bolts to the bell housing around the perimeter.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Lakewood Scatter-shield Blockplate ID #15781 [Re: 64dodge572] #1783138
03/19/15 03:38 PM
03/19/15 03:38 PM
P
P
Thanks Wayne. So it doesn't matter which one is used?
