UPDATE: Starter issues - resolved! #1782401
03/17/15 11:41 PM
03/17/15 11:41 PM
Maryland
wally426ci Offline OP
Maryland
68 D100 4 speed 318
This is the huge 3 bolt deal
My old napa starter started getting tight after the engine heated up. I replaced with another napa and it grinded every time i tried to start. That happened for a day or so and i loosened it and was able to rotate it slightly. I thought i cured it until a single time last weekend when it happened again.
Any ideas? Anyone ever put a dab of lithium grease on the teeth to help it mesh? <img src="/ubbthreads/images/graemlins/shruggy.gif" alt="" />
Re: Starter issues [Re: wally426ci] #1782402
03/18/15 12:38 AM
03/18/15 12:38 AM
No on the grease fixing it. I'll assume you tightened it good. bell bolts tight? otherwise take it off & another visual & see if you can see anything loose/out of whack. Something is changing (moving). Holler back with any news
Re: Starter issues [Re: RapidRobert] #1782403
03/18/15 12:58 AM
03/18/15 12:58 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Are you sure the flywheel teeth are not worn badly and causing a drag? Upon inspection you will notice, as I have, that the flywheel will have three areas of noticeable wear where the starter drive engages. That is about all the wear areas that could change over time...of course if the bolts from the bellhousing to the block have loosened that is a different matter. I have seen a lot of weird issues on the cars that rolled through the wrecking yard I worked in and I have not seen everything yet.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Starter issues [Re: RapidRobert] #1782404
03/18/15 07:25 AM
03/18/15 07:25 AM
Maryland
Maryland
Flywheel teeth were good in most areas. 1 area they were worn a little. Other area had burrs
Just seems wierd that it changed with the starter....
I thought about filing the starter bolt holes a little because it is hard to engage it manually with inspection cover off
Re: Starter issues [Re: wally426ci] #1782405
03/18/15 01:19 PM
03/18/15 01:19 PM
Maryland
Maryland
Anyone out there try altering the starter body mount holes?
Re: Starter issues [Re: wally426ci] #1782406
03/24/15 08:52 AM
03/24/15 08:52 AM
Maryland
Maryland
Ok, to follow up:
So far, I believe it is ok. I elongated the holes with a large rat tail file on the starter body itself. This allowed me to move it another 1/8" or so away from the flywheel in order for it engage nicely.
When I took it off before, I could see that it would hit the flywheel but not engage all of the time.
It is possible that the bell housing is slightly moved, but I thought these were like a 727 (mine is NP435) where they have dowels/pins.
Time will tell. Thanks for helping!
Re: Starter issues [Re: wally426ci] #1782407
03/24/15 01:45 PM
03/24/15 01:45 PM
thanks for the heads up as I have a BB/NP 435/hyd clutch setup going into a 65 D100 & I will check that (potential) issue when I get there
Re: Starter issues [Re: RapidRobert] #1782408
03/28/15 09:30 PM
03/28/15 09:30 PM
Maryland
Maryland
Back to square one. It did it again. It may be a coincidence but it seems to only be if the motor is hot after driving a while.
I may try another starter since the old one didn't do it. Is there anywhere I can send the old starter to get rebuilt?
Re: Starter issues [Re: wally426ci] #1782409
03/28/15 10:26 PM
03/28/15 10:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
not being a smart azz but try your yellow pages. most alternator shops also rebuild starters.
Re: Starter issues [Re: mikemee1331] #1782410
03/29/15 12:50 AM
03/29/15 12:50 AM
Maryland
Maryland
By all means! I actually did just google and will drop it off this week. Thanks for suggesting!
Re: Starter issues [Re: wally426ci] #1782411
03/29/15 01:16 AM
03/29/15 01:16 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Maybe you are missing a bell housing dowel.
Re: Starter issues [Re: NITROUSN] #1782412
03/29/15 09:49 AM
03/29/15 09:49 AM
Maryland
Maryland
The problem is the old starter would never grind when warm. The old one would crank slow.
Re: Starter issues [Re: wally426ci] #1782413
03/29/15 10:03 AM
03/29/15 10:03 AM
Maryland
Maryland
I may try installing the solenoid from the new starter onto the old to see how it goes.....
Re: Starter issues [Re: wally426ci] #1782414
03/29/15 10:03 AM
03/29/15 10:03 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
both indicate mis-alignment. maybe some shims?
Re: Starter issues [Re: mikemee1331] #1782415
03/29/15 01:37 PM
03/29/15 01:37 PM
Maryland
Maryland
I tried filing the holes but no luck so far.
Re: Starter issues [Re: wally426ci] #1782416
03/29/15 01:41 PM
03/29/15 01:41 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
have you actually looked at it while the starter is being engaged?
Re: Starter issues [Re: mikemee1331] #1782417
03/30/15 08:58 AM
03/30/15 08:58 AM
Maryland
Maryland
I did with the inspection cover off. I thought I had it engaging smoother. Now it is starting to seem like a heat related issue....
Re: Starter issues [Re: wally426ci] #1782418
03/30/15 09:29 AM
03/30/15 09:29 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I thought so too when I read this thread. Headers? you might have to fab up a heat shield or wrap the area of the exhaust near the starter.
Re: Starter issues [Re: mikemee1331] #1782419
03/30/15 10:59 AM
03/30/15 10:59 AM
Maryland
Maryland
Just manifolds. wierd issue but I will keep everyone posted on results
Re: Starter issues [Re: Polarapete] #1782420
03/31/15 12:17 AM
03/31/15 12:17 AM
Maryland
Maryland
Well it did it cold so not heat. I am dropping the old one off at a local shop but fearful that it could be the bad spot on the flywheel. Just doesn't make sense that it started grinding with the new starter....
