UPDATE: Starter issues - resolved!
#1782401
03/17/15 11:41 PM
03/17/15 11:41 PM
Posts: 2,554 Maryland
wally426ci
Maryland
68 D100 4 speed 318
This is the huge 3 bolt deal
My old napa starter started getting tight after the engine heated up. I replaced with another napa and it grinded every time i tried to start. That happened for a day or so and i loosened it and was able to rotate it slightly. I thought i cured it until a single time last weekend when it happened again.
Any ideas? Anyone ever put a dab of lithium grease on the teeth to help it mesh? <img src="/ubbthreads/images/graemlins/shruggy.gif" alt="" />
Re: Starter issues
[Re: wally426ci]
#1782402
03/18/15 12:38 AM
03/18/15 12:38 AM
RapidRobert
No on the grease fixing it. I'll assume you tightened it good. bell bolts tight? otherwise take it off & another visual & see if you can see anything loose/out of whack. Something is changing (moving). Holler back with any news
Re: Starter issues
[Re: wally426ci]
#1782406
03/24/15 08:52 AM
03/24/15 08:52 AM
wally426ci
Maryland
Ok, to follow up: So far, I believe it is ok. I elongated the holes with a large rat tail file on the starter body itself. This allowed me to move it another 1/8" or so away from the flywheel in order for it engage nicely. When I took it off before, I could see that it would hit the flywheel but not engage all of the time. It is possible that the bell housing is slightly moved, but I thought these were like a 727 (mine is NP435) where they have dowels/pins. Time will tell. Thanks for helping!
Re: Starter issues
[Re: wally426ci]
#1782407
03/24/15 01:45 PM
03/24/15 01:45 PM
RapidRobert
thanks for the heads up as I have a BB/NP 435/hyd clutch setup going into a 65 D100 & I will check that (potential) issue when I get there
Re: Starter issues
[Re: wally426ci]
#1782409
03/28/15 10:26 PM
03/28/15 10:26 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Back to square one. It did it again. It may be a coincidence but it seems to only be if the motor is hot after driving a while.
I may try another starter since the old one didn't do it. Is there anywhere I can send the old starter to get rebuilt?
not being a smart azz but try your yellow pages. most alternator shops also rebuild starters.
Re: Starter issues
[Re: wally426ci]
#1782414
03/29/15 10:03 AM
03/29/15 10:03 AM
mikemee1331
bethlehem pa
The problem is the old starter would never grind when warm. The old one would crank slow.
both indicate mis-alignment. maybe some shims?
Re: Starter issues
[Re: wally426ci]
#1782416
03/29/15 01:41 PM
03/29/15 01:41 PM
mikemee1331
bethlehem pa
I tried filing the holes but no luck so far.
have you actually looked at it while the starter is being engaged?
Re: Starter issues
[Re: wally426ci]
#1782418
03/30/15 09:29 AM
03/30/15 09:29 AM
mikemee1331
bethlehem pa
I did with the inspection cover off. I thought I had it engaging smoother. Now it is starting to seem like a heat related issue....
I thought so too when I read this thread. Headers? you might have to fab up a heat shield or wrap the area of the exhaust near the starter.
