Diesel oil #1782008
03/17/15 05:22 PM
03/17/15 05:22 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Hi, Just wonder how many, if any people here use Diesel oil in their BB
Heard it has a higher zinc content, if so what grade, Read somewhere 15-40 w
Thanks. Also I see Lucas has a regular oil base with zinc
Re: Diesel oil [Re: 300_dup5] #1782009
03/17/15 05:40 PM
03/17/15 05:40 PM
dogdays Offline
dogdays  Offline
Use the search function, the topic has been like a cat...every time we beat it to death it finds another life and comes back.
The short answer is "yes".
R.
Re: Diesel oil [Re: 300_dup5] #1782010
03/17/15 06:04 PM
03/17/15 06:04 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use either Mobil Delvac or Shell Rotella 15w40.
Nautilus Racing-
Re: Diesel oil [Re: Chris2581] #1782011
03/17/15 07:17 PM
03/17/15 07:17 PM
San Diego
Instigate Offline
Instigate  Offline
San Diego
I just add a zinc additive to regular oil for my non-roller engine.
Re: Diesel oil [Re: Instigate] #1782012
03/17/15 11:50 PM
03/17/15 11:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Diesel oil [Re: TJP] #1782013
03/18/15 12:25 AM
03/18/15 12:25 AM
BDW Online content
BDW  Online Content
$15 at Advanced Auto, enough for 3 oil changes.
Lucas break in zinc additive
Re: Diesel oil [Re: BDW] #1782014
03/18/15 01:26 PM
03/18/15 01:26 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use it, because I always have it around for my truck. It's also cheaper
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Diesel oil [Re: 300_dup5] #1782015
03/18/15 01:45 PM
03/18/15 01:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Maybe the oil is different north of the border ? But I thought the EPA mandate had zinc removed from Diesel oil too ? Maybe not as much as from the passenger segment but enough to warramt it not being a good enough alternative for flat tappet use ?
I just use Valvoline VR-1 10/30 non synthetic ...
Re: Diesel oil [Re: JohnRR] #1782016
03/18/15 02:32 PM
03/18/15 02:32 PM
UP
finn Offline
finn  Offline
UP
The EPA doesn't have limits on zinc limits for motor oil.
The limits are established by the auto makers and the API, based on what is required for catalytic converter life to meet EPA exhaust emission limits at end of life.
It is a subtle but important difference.
Re: Diesel oil [Re: 300_dup5] #1782017
03/18/15 05:06 PM
03/18/15 05:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With the introduction of catalytic converters on diesels I wouldn't trust any older specs for ZDDP content in diesel oils.
Re: Diesel oil [Re: 300_dup5] #1782018
03/19/15 11:07 AM
03/19/15 11:07 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
Rotella has the DPF (diesel particulate filter) compliant additive package, which means the ZDDP level is reduced from the original level. Also, the current CJ-4 API rating on Rotella T mandates a higher level of dispersant additives, and these dispersant additives compete against the formation of the ZDDP anti-wear film. In slower speed diesel engines, this is not a problem. However, it is an issue in higher speed, flat tappet, gasoline engines.
