Re: Installed my brake lines today
[Re: dart4forte]
#1781637
03/17/15 12:28 AM
03/17/15 12:28 AM
RapidRobert
You mean the splitter block in the front RF/LF) line? If so yes that is only a splitter. If no, holler back
[Re: RapidRobert]
#1781638
03/17/15 01:14 AM
03/17/15 01:14 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
That's what I'm thinking. I saved the old line however the block is missing. Can't remember if it was on when I disassembled the car.
[Re: dart4forte]
#1781639
03/17/15 01:52 AM
03/17/15 01:52 AM
RapidRobert
The line coming forward to energize the front brakes, it splits at a T & a brass triple female inverted flare block from the Edelman cabinet at your parts house ain't OE but will function fine. The (2) out ports take a 3/16 brake line/male inverted flare fitting. Not sure if the "in" line is the same dia (3/16") or 1/4". Get the right block & your set
