Any idea where these test results came from? #178104
12/29/08 05:40 PM
12/29/08 05:40 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I have an idea, but never actually bothered to buy a copy of the book... Does anyone recognize this? If you look closely at the chart, the rocker changes are specific to only the outboard cylinders; the footnote I found w/ the chart indicated the rocker changes to the inboard cylinders resulted in losing power.
Re: Any idea where these test results came from? [Re: BradH] #178105
12/30/08 12:19 PM
12/30/08 12:19 PM
BradH Offline OP
BradH  Offline OP
Re: Any idea where these test results came from? [Re: BradH] #178106
12/30/08 12:48 PM
12/30/08 12:48 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I vaguely remember a Circle Track mag article where they tried swapping rockers on a SBC. They tried all sorts of combos and did find improvement when the end cylinders were different than the middle ones. Sometime in the late 80s....
Re: Any idea where these test results came from? [Re: BradH] #178107
12/30/08 02:04 PM
12/30/08 02:04 PM
AndyF Online content
AndyF  Online Content
That chart is from one of the Chevy Power books. Chevy used to make those books every few years (like the old Direct Connection bibles) but I don't think they printed a new edition for a quite a while now.
Re: Any idea where these test results came from? [Re: AndyF] #178108
12/30/08 02:53 PM
12/30/08 02:53 PM
BradH Offline OP
BradH  Offline OP
Yeah, that's what I suspected. There was an older copy of some Chevy-specific publication on the book shelf at a semi-local speed shop that had an article on this stuff, but I never actually read it.
I would have expected the approach to have been putting the higher ratio rockers on the INBOARD runners, since what I've seen from flow bench testing bb Mopar intakes is that the longer & less restricted outboard runners typically flow better.
Questions raised by this graph:
a) Does the same thing apply to typical sb Chevy single-plane intakes?
b) Does this indicate that the increased dry flow of the outboard runner is offset by the additional wet flow frictional losses caused by the longer runner?
c) Am I freakin' lost in the theoretical clouds?
Re: Any idea where these test results came from? [Re: BradH] #178109
12/30/08 03:02 PM
12/30/08 03:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To me it just sounds like a imbalance in the intake
and they covered it up with the rockers. If they
had EGT's in all of the pipes it might have shown it
Re: Any idea where these test results came from? [Re: BradH] #178110
12/30/08 04:37 PM
12/30/08 04:37 PM
That was a NASCAR engine they were working on and for some reason it liked higher ratios on the outboard four cylinders. When they put the higher ratio rocker arms on all eight cylinders they lost power.
The difference was only 4 hp so they were really looking for tiny gains. I've never even been on a dyno where I would trust a 4 hp difference as significant!
Re: Any idea where these test results came from? [Re: BradH] #178111
12/30/08 04:43 PM
12/30/08 04:43 PM
Houston, Texas
FastOrange Offline
FastOrange  Offline
Houston, Texas
It sounds like you're snowed in to me
