Voltage at the coil when starting #1780759
03/15/15 06:04 PM
03/15/15 06:04 PM
Cincinnati, OH
68red440 Offline OP
68red440  Offline OP
Cincinnati, OH
I'm helping a friend get his 383 started in a '67 Polara. It measures 8V at the coil when cranking. Is that too low to fire the plugs?
Re: Voltage at the coil when starting [Re: 68red440] #1780760
03/15/15 06:28 PM
03/15/15 06:28 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That sounds about right to me.
Re: Voltage at the coil when starting [Re: Lefty] #1780761
03/15/15 06:31 PM
03/15/15 06:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think it really depends on what your ignition system consists of.
Stock, probably about right for an older unmaintained setup.
Don't be the exception.
Re: Voltage at the coil when starting [Re: Supercuda] #1780762
03/15/15 07:09 PM
03/15/15 07:09 PM
Cincinnati, OH
68red440 Offline OP
68red440  Offline OP
Cincinnati, OH
Thanks. It is a stock single point ignition system. The engine hasn't run in a few years.
Re: Voltage at the coil when starting [Re: 68red440] #1780763
03/15/15 07:36 PM
03/15/15 07:36 PM
The number I remember from the 60's which'd be points like yours is 9.6V min cranking. Not sure if 8V is the issue. More info on what is going on with the rest of the system. What is makin you think ign issue right now? Cranks good? blue or yellow spark? carb/fuel up to snuff? EDIT With more thought that 9.6V would have been at the batt tho with adequate voltage drops it would not be in the eights at the coil
Re: Voltage at the coil when starting [Re: RapidRobert] #1780764
03/15/15 08:08 PM
03/15/15 08:08 PM
IN
ahy Offline
ahy  Offline
IN
When cranking, the ballast resistor should be bypassed with the ignition switch on "start". The coil gets full battery voltage which is pulled down by the load of the starter. 8 volts sounds about right or maybe a touch low. Still should be plenty to make a decent spark.
You could check voltage at the battery while cranking... if its 8 volts or a bit more, all is well with the wiring. If you get much difference (more than .75 volts or so) there may be some dirty connections (bulkhead or ignition switch or other).
Re: Voltage at the coil when starting [Re: 68red440] #1780765
03/16/15 01:53 AM
03/16/15 01:53 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Too low...
Assuming the battery is fully charged..
Measured voltage @ the battery should be at least 10.5V-11V. Measured voltage @ the coil should be at least 10V as the ballast resistor is bypassed when cranking, once the engine is running it may drop down to 8V-9V..
Just my $0.02...
Re: Voltage at the coil when starting [Re: Sinitro] #1780766
03/16/15 07:51 AM
03/16/15 07:51 AM
Cincinnati, OH
68red440 Offline OP
68red440  Offline OP
Cincinnati, OH
Thanks for the info. We'll check battery voltage when it's cranking. It's getting fuel. He installed new plugs, cap, rotor, points, condenser, and coil. Timing is set. He pulled a plug and had spark, but not sure what color.
One time it sputtered for a second before shutting off. He's been using a remote starter so the key has only been in the run position when testing.
Re: Voltage at the coil when starting [Re: 68red440] #1780767
03/16/15 01:39 PM
03/16/15 01:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
With the key in the run position he is getting power through the ballast resistor to the coil which is what you are measuring. The voltage is correct for run. The start position of the ignition bypasses the resistor an give full battery voltage to the coil.
Re: Voltage at the coil when starting [Re: 68red440] #1780768
03/16/15 02:01 PM
03/16/15 02:01 PM
AndyF Online content
AndyF  Online Content
Check the BATT voltage when cranking. If it is also 8V then you don't have an ignition problem but you might have a BATT problem or a wiring problem.
