rearend swap brake??? #1780497
03/15/15 10:55 AM
03/15/15 10:55 AM
NY usa
540challenger Offline OP
NY usa
72,dart currently I have an 8 1/4 in it. Putting an 8,3/4 in. Will the backing plates and drums swap over???
Re: rearend swap brake??? [Re: 540challenger] #1780498
03/15/15 11:52 AM
03/15/15 11:52 AM
I'm assuming cutdown BBP 8&3/4. If so I believe you're good
Re: rearend swap brake??? [Re: RapidRobert] #1780499
03/15/15 12:15 PM
03/15/15 12:15 PM
NY usa
NY usa
Stock a-body housing with bbp axles
Re: rearend swap brake??? [Re: 540challenger] #1780500
03/15/15 07:41 PM
03/15/15 07:41 PM
with cutdown BBP axles or custom ones with the same standout (& likely yours are) as OE BBP axles I think you're good
Re: rearend swap brake??? [Re: 540challenger] #1780501
03/15/15 07:51 PM
03/15/15 07:51 PM
Stock a-body housing with BBp axles
The pre 1973 A body with 8 3/4 rear ends had narrower brakes and axle spacing from the wheel bearings to the axle flanges, you have to use the same drums that match the backing plates and axle to bearing spacing. The standard BBP axles usually have a larger diameter axle flange also that won't allow the stock A body 1 3/4 brake drums to fit on those flanges aso, you can have that fixed by a machine shop by having them reduce the O.D. to match the brake drum steps Been there, done that Another opton is to find a 1973 and later A body 8 1/4 rear end to get those stock brake from with the BBP, they bolt on the 8 3/4 and work with the standard 30 spline 8 3/4 axles as well as the Dana 35 spline BBP axles Let us know what you end up doing
Re: rearend swap brake??? [Re: Cab_Burge] #1780502
03/15/15 08:18 PM
03/15/15 08:18 PM
NY usa
NY usa
Thanks guys for the info I will be doing the swap in next weekend if the weather holds up
