1966 Torqueflight kickdown question
#1780448
03/15/15 10:23 AM
03/15/15 10:23 AM
Posts: 1,878 Detroit, MI
GetAwayDriver
Detroit, MI
I don't really consider this a "tech" question, just want to know if anyone has seen this set-up... I just bought a '66 Imperial. After driving it about 30 feet, I knew the trans wasn't working correctly. (The car was in a warehouse and I needed to move it towards better lighting to look it over.) After pulling the dipstick, my fear was confirmed, the fluid smelled like poo and was brown rather than red. I still bought the car, but had it trucked home. I just dropped the pan and the blood-letting began. I'm hoping it was a good sign that the converter drain landed at 6 o'clock so no under-car cranking required! Then I noticed something I'd never seen/noticed before... There is a piece of linkage sticking out of the floorpan, pretty much where the accel pedal would be located. However, it's just a rod with the bell-crank ball sticking out. It's not connected to anything. This can't be throttle linkage because the accel pedal functions normally, so I figure this must be the kickdown. Also makes sense because no kickdown would burn up the trans. (I didn't investigate further yet... Just wanted to shower the burned trans fluid out of my eyes and hair.) But now I'm thinking this might be a one-year-only part because the '65 TF was cable operated, '66 was the last year before the Imperial was completely redesigned. So my question is, "Was this kickdown linkage a one-year Imperial-only design, or was this used across multiple years/models?"Anybody know where I could find a photo/drawing of this part? I'll either have to fab it or find it. I've only dealt with the later 60s version that actuates the kickdown from the throttle shaft. I asked my '51 Imperial and it said "What is an automatic transmission?"
Re: 1966 Torqueflight kickdown question
[Re: GetAwayDriver]
#1780450
03/15/15 03:48 PM
03/15/15 03:48 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
'66 FSM should answer the questions...
[Re: GetAwayDriver]
#1780451
03/15/15 05:57 PM
03/15/15 05:57 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The '66 Imperial would have the one-piece TP linkage i.e. a single rod runs directly from the carb to the lever on the trans...no bellcranks like the other Chrysler models. Similar to the 4th picture down on this archives page. http://www.moparts.org/Tech/Archive/auto/35.html
[Re: John_Kunkel]
#1780452
03/15/15 06:36 PM
03/15/15 06:36 PM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
Was that one of the cars from the estate sale in Dearborn? I saw all of the Imperials, and really wanted the '65 vert but that one sold almost immediately.
My '67 Imperial had the conventional bellcrank linkage, like my '68 300.
[Re: RSNOMO]
#1780453
03/15/15 06:40 PM
03/15/15 06:40 PM
Posts: 6,516 Santa Cruz, California
Lefty
Indeed, and wealth of info on setting it up proper.
[Re: Lefty]
#1780454
03/15/15 09:34 PM
03/15/15 09:34 PM
GetAwayDriver
Detroit, MI
True enough. However once you have FSMs for a few Mopars spanning a few years, most of the info transfers. For example, much of this car is the same as my '62. Except for oddball details like this...
I think with my eyes filled with burnt transfluid (my happy-place), I only noticed the bellcrank connected to nothing. I should have noticed there is a later-style kickdown that is intact and functional. A '64 uses push-buttons, '65 uses a shiftlever and cable, '66 uses rods/linkage. Somebody in Highland Park must have said "Meh, we're only running this body for another year, let's just leave the accel pedal a carryover part."
So the good news is, I don't have to hunt anything down. The "unknown" is if adjusting the band and fresh fluid will do the trick.
PS: I wasn't kidding about the happy-place thing. Yesterday/today was the first time in God-knows how long I was able to work with the door open, out in the sun. I miss the simple pleasure of just being able turn wrenches and work on old cars. If I was a millionaire, that's all I would do... On my own island.
[Re: GetAwayDriver]
#1780456
03/15/15 09:39 PM
03/15/15 09:39 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
C'mon C, it's toast...
Gonna be 65 tamarraw...
Call BA, and we'll get that trans on the ground...
[Re: Blusmbl]
#1780457
03/15/15 09:51 PM
03/15/15 09:51 PM
GetAwayDriver
Detroit, MI
I believe if your car was equipped with it, the cruise control linkage rod attaches to that bellcrank.
Son of a bi... It is equipped with cruise. Thanks for the heads up.
[Re: RSNOMO]
#1780458
03/15/15 10:01 PM
03/15/15 10:01 PM
GetAwayDriver
Detroit, MI
Yes, 65 degrees so I am told. And 30 the week after, so I have also been told.
And no matter how much of an A-team fan that you may be, I pity the fool who would rebuild a trans without at least trying a band adjustment.
[Re: Blusmbl]
#1780459
03/15/15 10:11 PM
03/15/15 10:11 PM
GetAwayDriver
Detroit, MI
Yes, this is one of those cars. I made a pretty fair offer on the one with a terrible paint job and they accepted. It's solid as a rock underneath (car is from Washington state), so I'll use that paint as a guide coat once the weather is warm enough to do paint work.
[Re: GetAwayDriver]
#1780462
03/16/15 08:56 AM
03/16/15 08:56 AM
Blusmbl
Plymouth, MI
Right on. The guy had nice taste in vintage luxury, that's for sure. I didn't realize they were negotiating on price. I think they started selling them off in December, those seemed to be going for fixed prices until the fleet dwindled.
On my '67 I never saw where the linkage rod attached to, but I definitely remember the "auto pilot" control unit on the driver's inner fender with an adjuster and a long rod that went down towards where the pedal assembly was. I still have the FSM for it and they don't show the pedal end, just the end by the control unit.
