Re: ??? about carburating a 5.2 1993 Dakota
[Re: Dakotamecrazy]
#1780335
03/15/15 04:07 PM
03/15/15 04:07 PM
Posts: 684 Maine
jerseybud
Maine
You're insane if you carb that truck. The 92-93 dakota should be one of the best bracket racers of the era once you get traction stabilized. A MP computer should still be available for that truck depending on tranny and the aftermarket is still there for the magnum engine. The performance aspect of the magnum engines has been beat to death- all the tricks are out there on the internet, like this http://bionicdodge.com/Download/Speedtweaks%20Tips%20And%20Tricks.pdfAgain, you should drive a chevy if you carb this truck. Seriously.
[Re: moparmojo]
#1780338
03/17/15 03:44 PM
03/17/15 03:44 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would keep the EFI, there are lots of tricks to make it work faster. I tried bracket racing my 95 neon auto back in the day figuring it would be consistant since traction was no issue and the EFI would do the same thing every time... only if I kept it idling and hot between laps AND I reset the adaptive fuel right before every round, it would be faster if I opened the hood and let everything cool off but guessing an ET was a crap shoot. It was better than my 66 dart ever was though.
[Re: Dakotamecrazy]
#1780341
03/18/15 12:10 AM
03/18/15 12:10 AM
HotRodDave
Kalispell Mt.
Hughes air-gap intake. Port the factory one yourself or get hughes to do their "big gulp" thingy to it. You can still use OBD 1. Just throw a little bigger injector out of a 460 in it and do the advance trick to the crank sensor. If you get a little more serious you can adapt a later model pump in it, they run a tad higher preassure. Having my own scanner to watch what the fuel trim is doing can give me an idea what to do to trick the computer into doing what I want but they are expensive. Might find someone to borrow one from and see what happens when you put it together. There are ways around needing a tuner although a tuner is best
