Brake Pedal Lower than Clutch Pedal 69 Charger #1780212
03/14/15 10:53 PM
03/14/15 10:53 PM
Canal Fulton, (Akron) Ohio
Q
Quicksmopars Offline OP
Q
Is there a way to adjust how high the brake pedal sits on my 69 Charger. On my car, the brake pedal is the same level as the gas pedal, which is well below the clutch pedal. Hopefully someone knows a fix for this?
Re: Brake Pedal Lower than Clutch Pedal 69 Charger [Re: Quicksmopars] #1780213
03/14/15 11:04 PM
03/14/15 11:04 PM
I think MP has an adjustable longer one but more info on what's going on. an alum MC has a piston recessed further into the MC and a 2/4 bolt adapter plate will also lower the pedal. I've seen several different lengths of manual brake pushrods. EDIT If this is power, I dont know power well & there was just a recent post on low PB pedals but I dont remember what it said
Re: Brake Pedal Lower than Clutch Pedal 69 Charger [Re: RapidRobert] #1780214
03/15/15 08:19 AM
03/15/15 08:19 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Lower pedal with power brakes. Normal situation.
Angry white pureblood male
Re: Brake Pedal Lower than Clutch Pedal 69 Charger [Re: ruderunner] #1780215
03/15/15 12:02 PM
03/15/15 12:02 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
I think this is normal and if you wanted to change that you would need to make the rod longer , but then if you pushed the brake pedal hard enough it would bottom out the master cylinder before the pedal was even close to hitting the floor. probably would not hurt it unless you had a super strong leg.
Re: Brake Pedal Lower than Clutch Pedal 69 Charger [Re: dirt] #1780216
03/15/15 02:31 PM
03/15/15 02:31 PM
Q
Q
It does have power disc brakes.
