Need highest quality lower ball joint
#1779937
03/14/15 06:39 PM
03/14/15 06:39 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Well, after singing their praises, my raybestos professional grade lower ball joints now have some play in them (after 6500 miles, a dozen or so track days, etc). I need a quality replacement. What's my best bet?
Thanks Wade
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Need highest quality lower ball joint
[Re: Uhcoog1]
#1779938
03/14/15 06:41 PM
03/14/15 06:41 PM
Uhcoog1
Houston Tx
Lots of ideas in this thread: https://board.moparts.org/ubbthreads/show...rue#Post8410666Just curious who's found long term success when running hard
[Re: Dan@Hotchkis]
#1779940
03/15/15 02:01 AM
03/15/15 02:01 AM
Uhcoog1
Houston Tx
Thanks Dan.
Did yall have problems with moog lower ball joints specifically? Or the uppers?
[Re: Uhcoog1]
#1779941
03/15/15 03:25 AM
03/15/15 03:25 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I don't think a high performance lower ball joint for Mopars exists. I have no experience with the ProForged lowers though... We may just have to compromise with stock replacements and change them out accordingly
[Re: Uhcoog1]
#1779944
03/15/15 12:25 PM
03/15/15 12:25 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Who knows if Moog is actually Made in USA or not? Howe makes a screw in lower ball joint for Chrysler https://www.howeracing.com/c-583-screw-in-chrysler-lowers.aspxNot sure how this works exactly? As for Moog or Howe making a direct replacement heavy duty racing lower ball joint for our cars, I only see that happening when a huge amount of Mopars are being driven around corners
[Re: RylisPro]
#1779945
03/15/15 01:24 PM
03/15/15 01:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
K 179 fits
CHRYSLER 300 (1962 - 1964) CHRYSLER CORDOBA (1975 - 1983) CHRYSLER FIFTH AVENUE (1983 - 1989) CHRYSLER IMPERIAL (1981 - 1983) CHRYSLER LEBARON (1977 - 1981) CHRYSLER NEW YORKER (1963 - 1982) CHRYSLER NEWPORT (1961 - 1981) CHRYSLER TOWN & COUNTRY (1963 - 1964) CHRYSLER WINDSOR (1958 - 1961) DODGE 880 (1963 - 1964) DODGE ASPEN (1976 - 1980) DODGE CHARGER (1973 - 1978) DODGE CORONET (1957 - 1976) DODGE CUSTOM (1957 - 1959) DODGE DART (1960 - 1961) DODGE DIPLOMAT (1977 - 1989) DODGE MAGNUM (1978 - 1979) DODGE MATADOR 1960 DODGE MIRADA (1980 - 1983) DODGE MONACO (1977 - 1978) DODGE POLARA (1960 - 1961) DODGE SIERRA 1959 DODGE ST. REGIS (1979 - 1981) DODGE SUBURBAN (1957 - 1958) PLYMOUTH BELVEDERE (1957 - 1961) PLYMOUTH CARAVELLE (1978 - 1989) PLYMOUTH FURY (1957 - 1978) PLYMOUTH GRAN FURY (1980 - 1989) PLYMOUTH PLAZA (1957 - 1958) PLYMOUTH ROADRUNNER (1973 - 1975) PLYMOUTH SATELLITE (1973 - 1974) PLYMOUTH SAVOY (1957 - 1961) PLYMOUTH SPORT WAGON (1960 - 1961) PLYMOUTH SUBURBAN (1957 - 1961) PLYMOUTH VOLARE (1976 - 1980)
K727 fits
CHRYSLER 300 (1960 - 1961) CHRYSLER IMPERIAL (1960 - 1966) CHRYSLER NEW YORKER (1960 - 1962) CHRYSLER SARATOGA 1960 DODGE B100 (1971 - 1980) DODGE B150 (1981 - 1994) DODGE B200 (1971 - 1980) DODGE B250 (1981 - 1994) DODGE B300 (1971 - 1980) DODGE B350 (1981 - 1994) DODGE CB300 (1974 - 1980) DODGE D100 PICKUP (1972 - 1989) DODGE D150 PICKUP (1977 - 1993) DODGE D200 PICKUP (1975 - 1980) DODGE RAMCHARGER (1974 - 1993) PLYMOUTH PB100 (1975 - 1980) PLYMOUTH PB100 VAN 1974 PLYMOUTH PB150 (1981 - 1983) PLYMOUTH PB200 (1975 - 1980) PLYMOUTH PB200 VAN 1974 PLYMOUTH PB250 (1981 - 1983) PLYMOUTH PB300 (1975 - 1980) PLYMOUTH PB300 VAN 1974 PLYMOUTH PB350 (1981 - 1983) PLYMOUTH TRAILDUSTER (1974 - 1981)
All of these have the ball joint in the LCA not the steering arm.
[Re: Supercuda]
#1779946
03/15/15 02:29 PM
03/15/15 02:29 PM
Uhcoog1
Houston Tx
Barring any new options: O'reilly's will have a pair of moog for me today. If they state 'made in america', I'll probably use them as I can put them in today. If they aren't clearly made in America, I'll order proforged.
Has anyone killed a set of moog or proforged yet? Or put them through the ringer and not have a failure?
[Re: Uhcoog1]
#1779948
03/15/15 04:07 PM
03/15/15 04:07 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Thanks Wade
How much play did they have? There is a spec somewhere, just wondering if you are over spec or not.
[Re: ntstlgl1970]
#1779949
03/15/15 06:10 PM
03/15/15 06:10 PM
Uhcoog1
Houston Tx
Thanks Wade
It moves enough that I want to replace it before getting an alignment and putting new track rubber on the car. Lower ball joints are a lot cheaper than hoosier tires.
[Re: Lefty]
#1779951
03/15/15 09:26 PM
03/15/15 09:26 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
I don't think any of the "stock replacement" ball joints will last very long on a sticky tire track car.
With today's offshore manufacturing, I tend to agree.
Best approach may be to hog out the ball joint in a lower steering arm set up and bore/weld/install a threaded sleeve for an upper ball joint so you can have fixed steering arms and a removeable ball joint that can be easily replaced.
This is similar to how most oval track set ups are these days, which actually very closely resemble 73-80 B body lowers.
[Re: Uhcoog1]
#1779954
03/16/15 11:55 AM
03/16/15 11:55 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Another choice to consider are TRW suspension parts. Historically, TRW has been the primary OE domestic parts suspension supplier and "Made in America" accordingly; Moog is diminantly aftermarket and has an excellent reputation, especially for introducing their "Problem Solver" parts that are intended to fix notorious aftermarket, as well as some OE, common and repeated problems. Unfortunately, for many suppliers, they've been changing their manufacturing oversease simply for cost reductions to compete against other imported lower-cost suppliers, and... you pay for what you get.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: TC@HP2]
#1779955
03/16/15 10:32 PM
03/16/15 10:32 PM
Posts: 19,470 north of coder
moparx
upper joints are not designed to be the "load bearing" joint. you need a lower screw in joint such as a K719 or K727. the 719 joint is the same thread as the upper K772 joint, while the K727 is the larger diameter threads that i think are the same as the K778 upper joint used in C bodies and pickups.
