Reverse Lights stay on, Switch was replaced... #1779760
03/14/15 05:18 PM
03/14/15 05:18 PM
Somewhere near Palm Springs
ConvertiBee Offline OP
I thought that replacing the (727) trans switch would surely solve this problem in my '70 convert... so I did that, and they STILL stay on in Drive, 2nd, 1st. I checked the wires underneath the car and they don't appear grounded... What next??
[img]https://photos.google.com/search/_tra_/photo/AF1QipP622C0UgUgrRn9SDVmwoPXVW4gJ4A2UcAzWOit[/img]
'69 GTX 440 D21 A34 N96
'70 Coronet 383 'Vert
'71 Demon 340 SixPack 4-Speed
'72 Cuda 340 FE5
'74 Kawasaki Z1, and...
(12) Japanese Enduro's and SuperBikes from the 1970's! smile
Re: Reverse Lights stay on, Switch was replaced... [Re: ConvertiBee] #1779761
03/14/15 05:52 PM
03/14/15 05:52 PM
That IS a nice ride . pull the connector back off of the 3 pin switch on the trans and (1) see if there is continuity (ohm it) between the 2 outer male pins (key on/trans in any gear except reverse). if yes the problem is in the switch or the rooster comb inside the trans and there was something about some aftermarket switches the contact that touches the comb is too long or too short I forget which caused a similar/related problem but since the other switch you replaced there was the same issue I'll assume that that (wrong/bad switch) ain't an issue. (2) if no continuity see if both outer female cavities in the connector have fire (key on) & one should & the other should not but if it does then there's continuity right there in the connector (not likely) or there's a wiring problem upstream (start at the bulkhead) thats feeding current to the one outer pin wire that goes to the reverse lights as only the switch should be connecting the two outer pins. The center pin if for the NSS & ain't involved in this so leave it alone. www.mymopar.com has the colors
Re: Reverse Lights stay on, Switch was replaced... [Re: ConvertiBee] #1779762
03/14/15 06:05 PM
03/14/15 06:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
With the lights on in a forward gear unplug the switch. If the lights go out the problem is internal. Only reason I say that is two switches are doing the same thing. 68 and older valve bodies have a different rooster comb. Any chance that your valve body has been replaced?
Re: Reverse Lights stay on, Switch was replaced... [Re: NITROUSN] #1779763
03/14/15 06:16 PM
03/14/15 06:16 PM
THANKS for your replies! The reverse lights go out with the switch unplugged... I don't know if anythnig has ever been done with the vavlvebody, the trans has performed 100% in the 14 years I've owned this car.
Re: Reverse Lights stay on, Switch was replaced... [Re: ConvertiBee] #1779764
03/14/15 06:37 PM
03/14/15 06:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Inside the trans there is a plastic shoe that sometimes breaks off...this will allow the BU lights to be on in gears other than Reverse.
