Page 3 of 3 1 2 3
Re: 60' still stinks [Re: weedlayer] #1779413
03/16/15 08:07 PM
03/16/15 08:07 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
It's that oil pan
Re: 60' still stinks [Re: Leigh] #1779414
03/17/15 08:40 AM
03/17/15 08:40 AM
CheddarHead till October
weedlayer Offline OP
It's that oil pan
Me and that pan are still in training
Re: 60' still stinks [Re: weedlayer] #1779415
03/17/15 08:49 AM
03/17/15 08:49 AM
tboomer Offline
tboomer  Offline
No help to ya Ray but that old pack mule looks pretty good! I am sure you will get it figured out!
Re: 60' still stinks [Re: weedlayer] #1779416
03/17/15 10:09 AM
03/17/15 10:09 AM
gregsdart Offline
gregsdart  Offline
The closet I can get to that according to my program would be the following
That also means I went the wrong way again.
I don't really care about chasing et, just want to optimize the set up for consistency.
Once you get the right setup, you will get both. I would go a tad shorter, say 36 to 38 inch out, and about 7 to 8 inch high for starters. That is close to a ladder bar setup, but just a tad softer due to the length. My thinking is be just above 100 percent anti squat. Too much anti squat try's to raise the back of the car too violently, and the force applied momentarily pushes the nose down due to the opposite and equal reaction around the Cg. That momentary force only lasts for a very short instant, but it puts energy into the front end in the wrong direction. I believe a 10.30 car is too fast for that to work. Another thing is spring rates. Too much is a killer. Too little needs a lot of shock to control. What do you have on both ends?
Page 3 of 3 1 2 3
