Re: 60' still stinks
[Re: weedlayer]
#1779374
03/14/15 03:05 PM
03/14/15 03:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I couldnt load the vid.. but is it spinning.. what is the front of the car doing.. and is the back lifting up or staying pretty even with the slick
[Re: Harley]
#1779377
03/14/15 04:11 PM
03/14/15 04:11 PM
Posts: 642 New Jersey
Craig
New Jersey
What rear shocks and what setting? In the vid, looks like no rise in back which you should have with that 4-link setting. Looks like rear shocks need the extension loosened.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: Craig]
#1779378
03/14/15 04:24 PM
03/14/15 04:24 PM
Quicktree
[Re: weedlayer]
#1779381
03/14/15 08:19 PM
03/14/15 08:19 PM
Posts: 10,007 Frostbitefalls MN (Rocky&Bullw...
gregsdart
What is the most travel you can get out of the front end? Rear? I would start full lose, max travel on both ends, with a video looking at the rear from an angle, hopefully including the front tires as well. It looks like the rear hit, stuck for an instant, then spun, so it might be too aggressive at this point, with the front too stiff as well. Any idea of how much stall the converter has , and where is your torque peak?.
[Re: weedlayer]
#1779382
03/14/15 08:38 PM
03/14/15 08:38 PM
MR_P_BODY
What rpm are you leaving at.. might want to try a LOT more to plant the tire.. I have the same issue if I dont leave hard
[Re: Quicktree]
#1779386
03/14/15 09:25 PM
03/14/15 09:25 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Those huge rear tires eat up a lot of steam. Bet it would 60 foot better with way less under it.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1779388
03/14/15 10:03 PM
03/14/15 10:03 PM
Quicktree
yes they do, but it doesn't spin
[Re: Cab_Burge]
#1779389
03/14/15 10:06 PM
03/14/15 10:06 PM
Quicktree
It looks like and sounds like it porpoised on the starting line, front and back started to rise and then the back slips back down, try stiffening up the compression, not the extension, on the rear shocks only. Take one of each (front and rear)shocks off and experiment with the settings on a bench so you know which adjustments does what to your shocks One other thing when you jack the car up to remove the shocks, check to make sure you have enough travel on both ends with the suspension fully extended down that the shocks have more travel left in them, not held up tight enough to hold the suspension up
I didn't see or hear that at all sounded more like a tight converter to me.
[Re: abodiesonly1]
#1779392
03/15/15 12:55 AM
03/15/15 12:55 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Its dead hooking and bogging ever so slightly, but you can hear it.
Converter doesn't flash in the slightest.
I disagree, from the Vid, its not dead hooking. Sure, its not the greatest vid.
Its hard to tell by looking at the slick alone, but if you focus on the rim, it spins about a revolution and a half or so. Im assuming the slick is too, hard to see it.
