Want to do some Diesel Drag Racing #1779220
03/13/15 10:57 PM
03/13/15 10:57 PM
smyrna,tn
draginmopars Offline OP
smyrna,tn
need some help with a plan
1/8 mile track>> Street class>> 8.50 dial-in
parts list
89 engine
727 trans
4.10 Dana with a spool,
31 x 13-15 tire
35 spline axles
also 92 engine, turbo and OD trans
have pyro, boost gauges
will be porting the exhaust ports and match porting the manifold
what to do ?
4000 GSK
60 or 110 springs
converter>> stock, add anti-ballooning plates or ?
would I keep the 4.10 or still go to a 3.54 ( next gear I have)
also have a 4.56 gear laying around
If i use the OD Trans
what about wiring in a pressure switch
in the governor port
example>> 52psi= 52mph
to turn on OD
will it hurt the trans to shift into OD, under load?
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Want to do some Diesel Drag Racing [Re: draginmopars] #1779221
03/15/15 09:39 AM
03/15/15 09:39 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
You need to contact CumminsExpress or find a better site for that info.
