Mini-tubbing wide rubber & 8 3/4 rear questions 83 D150 #1779124
03/13/15 08:38 PM
03/13/15 08:38 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Hi guys,
I 'm pretty stoked, just picked up a clean 83 D150 318/4 spd short box. Can anyone provide a link to a thread or website about mini-tubbing, wheel/rubber combos and using a 8 3/4 rear in these addictive little things. I have an A-body 8 3/4" housing already and would like to use it. Using it how wide rubber can a guy fit into one of these --tubs notwithstanding.
The plan is to put a 540 hp 371 I have in it, lower it using the van LCA's and car rear spring perch method. I want this to be a clean little runner that I can upgrade as I go. Next winter it will receive a G3 stroked HEMI and a McLeod 5 spd.
I would like a real decent driver that can surprise unsuspecting NEW LS/G3 car owners. Thanks. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Mini-tubbing wide rubber & 8 3/4 rear questions 83 D150 [Re: RAMM] #1779125
03/13/15 08:40 PM
03/13/15 08:40 PM
RAMM Offline OP
RAMM  Offline OP
Forgot to ask--Looking for a widened Cop Car wheel and Dog dish hubcap vibe on the wheels. I don't want a pro-street size tire--just a 315-335 series on the back and 275's up front. J.Rob
Re: Mini-tubbing wide rubber & 8 3/4 rear questions 83 D150 [Re: RAMM] #1779126
03/13/15 09:05 PM
03/13/15 09:05 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Scratchy can get you info on wide tires without tubs. Sounds like a cool project.
Surprising what you can make work.
Re: Mini-tubbing wide rubber & 8 3/4 rear questions 83 D150 [Re: RAMM] #1779127
03/13/15 10:40 PM
03/13/15 10:40 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Bumping stuff for you
