Steering Column Installation. How do you get leverage? #1779103
03/13/15 08:07 PM
03/13/15 08:07 PM
Georgia
Steve Bryant Offline OP
Georgia
The FirmFeel is in place and I can get the column lined up but I can't figure out how to get leverage to push the column down on the steering box.
I cleaned and degreased the fitting and I can get about 1/8"-1/4" started but I can't slide it any further with my hands alone. There is no room in there for a hammer or a clamp.
I've spent about 90 minutes on it and figure I must be missing something.
Any tricks or ideas?
Re: Steering Column Installation. How do you get leverage? [Re: Steve Bryant] #1779104
03/13/15 08:10 PM
03/13/15 08:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The notch in your coupler has to line up with the master spline on the steering box shaft.
Re: Steering Column Installation. How do you get leverage? [Re: Alaskan_TA] #1779105
03/13/15 08:15 PM
03/13/15 08:15 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Take the coupler off the steering box. Then turn the steering box shaft till it stops and then in the other direction till it stops counting how many turns. Go back half the amount of turns and master spline will be on top.
bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Steering Column Installation. How do you get leverage? [Re: VCODE] #1779106
03/13/15 08:35 PM
03/13/15 08:35 PM
Georgia
Georgia
Since there is no steering wheel yet on the column, I disconnected the two, rotated the column shaft and was able to get them to align up.
This helped me slide them another 1/4" or so together but I am still about an inch away from being able to hammer in the roll pin. I am going to attach the wheel and try to turn the wheel a little bit to make sure everything is lined up good.
Re: Steering Column Installation. How do you get leverage? [Re: Steve Bryant] #1779107
03/13/15 08:47 PM
03/13/15 08:47 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do you have an service manual? You really need one.
Re: Steering Column Installation. How do you get leverage? [Re: Steve Bryant] #1779108
03/13/15 08:58 PM
03/13/15 08:58 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
Sounds like you have a damaged spline. You might be able to dress it with a jewelers file.
Mine did not require any hammering to put on.
Re: Steering Column Installation. How do you get leverage? [Re: 71birdJ68] #1779109
03/13/15 09:05 PM
03/13/15 09:05 PM
Georgia
Georgia
Got it on there. There was a small burr in the joint and once I took that out (and aligned the marks in the shaft) the two slid together.
As for the service manual, I do have one. Section 19-44 describes exactly what I am doing but it simply says "With front wheels in straight ahead position and master splines on wormshaft and coupling aligned, engage coupling and wormshaft and install the roll pin"
Fortunately, you guys pointed out my mistake with the alignment and all is well now.
Many, many thanks for the help
-Steve
Re: Steering Column Installation. How do you get leverage? [Re: Steve Bryant] #1779110
03/14/15 03:44 AM
03/14/15 03:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have removed and installed several steering columns and it has been rare to have one slip on right away. Of course I'm always working alone, cussing and yelling at it. Having a helper would be great.
