Sumped tank or fuel cell? #177889
12/29/08 12:53 PM
12/29/08 12:53 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I have a sumped tank in my car right now and still run all the stock interior with a cage and I am stepping the car up and with my new fuel pump I need a to run a return line and not sure if I should put one in the tank or put a fuel cell in the trunk? I know I will have to take the back seat out and install a fire wall.Any thoughts? I am looking to go from from running 11.80.s to 10.50's
Switched to the dark side...
Re: Sumped tank or fuel cell? [Re: JSR1485] #177890
12/29/08 01:56 PM
12/29/08 01:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you drive it on the street and use the trunk
much, if so stay with the tank you have, if not
I think I'd go with a cell.... JMO
Re: Sumped tank or fuel cell? [Re: JSR1485] #177891
12/29/08 02:09 PM
12/29/08 02:09 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
I prefer a tank on an otherwise stock looking car. You can always keep the tank but lose the sending unit. You can have a dual outlet welded into the lower part of the tank and then run an electric pump.
RS23L7 4-Speed
Re: Sumped tank or fuel cell? [Re: Mopar_Mike] #177892
12/29/08 02:29 PM
12/29/08 02:29 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I like the looks of the stock tank, and having the weight lower helps cornering on the street.
Moving the weight of the fuel cell into the trunk can help weight transfer when drag racing
Re: Sumped tank or fuel cell? [Re: Mopar_Mike] #177893
12/29/08 02:30 PM
12/29/08 02:30 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We run a sumped stock tank, it's a CE piece with 2 3/8 npt (-8) outlets that go to a holley Dominator 250 gph fuel pump. We used the original pick up as the return with a tube nut/-6 fitting.
Hope this helps
Link to tubenut fitting thingy. http://www.earls.co.uk/earls/hoseends/tubefit.html
Re: Sumped tank or fuel cell? [Re: Tig] #177894
12/29/08 02:45 PM
12/29/08 02:45 PM
an8sec70cuda Offline
Stock tank w/ a sump here too. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Sumped tank or fuel cell? [Re: Tig] #177895
12/29/08 03:03 PM
12/29/08 03:03 PM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
Hope this helps
This is what i planned to do with mine.
Re: Sumped tank or fuel cell? [Re: Tig] #177896
12/29/08 04:38 PM
12/29/08 04:38 PM
Hope this helps I kept the stock tank in my street Duster (10:34 ET at 128.6MPH) and used the original pick up hole to have #8 stainless hard line bent and welded so it dumps into the bottom of the tank. I kept the fuel level float assembly so the fuel gauge works I had a round stainless sump weleded into the bottom with a #10 AN nipple as the outlet. The shop that did the return line said that was the only way to get the #10 outlet covered in gasoline all the time was to have a lowered, three inch deep and 4 inch round sump It does work well
Re: Sumped tank or fuel cell? [Re: Cab_Burge] #177897
12/29/08 05:31 PM
12/29/08 05:31 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The worst thing about the stock tank, is that even with a sump, you still have to keep a lot of gas in it, to keep it from uncovering the pickup at launch. Stock caps, also have a tendency to leak at launch when the tank is full. Just a personal thing, but I just don't like a tank full of fuel in a car at the track. If it is a race only piece, put a 2-3 gallon cell in it and fill it after every run. If you still drive it some, get a little larger one.
Monte
Re: Sumped tank or fuel cell? [Re: Monte_Smith] #177898
12/29/08 08:43 PM
12/29/08 08:43 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
Thanks Guys for all the input, no the car is not run on the street it is Race only. One problem I run into just as Monte said, I have to way too much fuel and with no factory harness or gauges working I have no idea on the amount of fuel in the car either. I try to guess a 1/2 gallon a run and after a few weeks I have to drain it and usally end up with way too much in the car. I was thinking about a 5 gallon aluminum tank mounted in the spare tire well along with puting the pump and filter along side of it also.
Re: Sumped tank or fuel cell? [Re: JSR1485] #177899
12/30/08 07:51 AM
12/30/08 07:51 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Here is a pic of the sump we use, we've ran the tank as low as 1/8th full on the gauge with no problems. We generally keep the tank 1/2 full for consistancy and the extra wieght at the rear but the safety aspect of so much fuel (10 us gall?) is always on your mind. Btw some fuel cells come with the option of a level sender which can be hooked up to a autometer gauge.
