Sumped tank or fuel cell?
#177889
12/29/08 12:53 PM
12/29/08 12:53 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
I have a sumped tank in my car right now and still run all the stock interior with a cage and I am stepping the car up and with my new fuel pump I need a to run a return line and not sure if I should put one in the tank or put a fuel cell in the trunk? I know I will have to take the back seat out and install a fire wall.Any thoughts? I am looking to go from from running 11.80.s to 10.50's
Switched to the dark side...
Re: Sumped tank or fuel cell?
[Re: JSR1485]
#177890
12/29/08 01:56 PM
12/29/08 01:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you drive it on the street and use the trunk much, if so stay with the tank you have, if not I think I'd go with a cell.... JMO
[Re: JSR1485]
#177891
12/29/08 02:09 PM
12/29/08 02:09 PM
Posts: 4,282 Danville, NH
Mopar_Mike
Danville, NH
I prefer a tank on an otherwise stock looking car. You can always keep the tank but lose the sending unit. You can have a dual outlet welded into the lower part of the tank and then run an electric pump.
RS23L7 4-Speed
[Re: Mopar_Mike]
#177893
12/29/08 02:30 PM
12/29/08 02:30 PM
Posts: 2,915 A shed in England
Tig
A shed in England
We run a sumped stock tank, it's a CE piece with 2 3/8 npt (-8) outlets that go to a holley Dominator 250 gph fuel pump. We used the original pick up as the return with a tube nut/-6 fitting. Hope this helps Link to tubenut fitting thingy. http://www.earls.co.uk/earls/hoseends/tubefit.html
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#177894
12/29/08 02:45 PM
12/29/08 02:45 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Stock tank w/ a sump here too. CHIP
[Re: Tig]
#177895
12/29/08 03:03 PM
12/29/08 03:03 PM
Posts: 1,476 Oh
RacerGofKGB
Got The Big One
Got The Big One
Oh
This is what i planned to do with mine.
[Re: Monte_Smith]
#177898
12/29/08 08:43 PM
12/29/08 08:43 PM
JSR1485
Seaford Delaware
Thanks Guys for all the input, no the car is not run on the street it is Race only. One problem I run into just as Monte said, I have to way too much fuel and with no factory harness or gauges working I have no idea on the amount of fuel in the car either. I try to guess a 1/2 gallon a run and after a few weeks I have to drain it and usally end up with way too much in the car. I was thinking about a 5 gallon aluminum tank mounted in the spare tire well along with puting the pump and filter along side of it also.
[Re: JSR1485]
#177899
12/30/08 07:51 AM
12/30/08 07:51 AM
Tig
A shed in England
Here is a pic of the sump we use, we've ran the tank as low as 1/8th full on the gauge with no problems. We generally keep the tank 1/2 full for consistancy and the extra wieght at the rear but the safety aspect of so much fuel (10 us gall?) is always on your mind. Btw some fuel cells come with the option of a level sender which can be hooked up to a autometer gauge.
